June 28, 2025, 08:03:44 AM *
Author Topic: Just reinstalled Cobra 6 into 6 exhaust on my 98 standard  (Read 2821 times)
Momz
ABATE, AMA, & MRF rep.
« on: April 01, 2009, 01:00:22 PM »
Has anyone had a hard time with the installation of their Cobra pipes?
When I removed the pipes, there were some fasteners missing, and I thought that it may be due to someone not being careful when the pipes were originally installed.
I am quite anal about things fitting properly and the use of new fasteners, using anti-seize on the threads, new gaskets and proper torque values. But these pipes were such a "Pain in the Azz" to line up the pipes aand at the rear mounts. As it turned out I had to leave out one of the bolts that mounts the pipes to the RH passenger peg bracket. This was missing when I took the pipes off and the holes/nut will not line up,
Have any others with these pipes experienced the same problem? I'd like to see your comments.
Thank you
ALWAYS QUESTION AUTHORITY!
mirion
1997 Std - 2000 IS
Frankenmuth, Michigan
« Reply #1 on: April 01, 2009, 01:35:59 PM »
I put a set on my 97 last year and it was a breeze. You did take them apart and put them on one pipe at a time, right. I have read of others having problems though.
