July 22, 2025, 12:28:30 AM *
Author Topic: AUx plug in  (Read 1196 times)
Alaskamike
gittin her done!
Wasilla, Alaska
« on: November 22, 2010, 10:39:15 PM »
QUick ?  before I 'hit the hay'.   Does anyone know if the auxillary plug in by the fuse box is  switched - meaning it works like the headlamp, and is off when turning key?
"If you don't ride in the rain.... you don't ride"
Colin
My old job
Orba, Spain
« Reply #1 on: November 22, 2010, 11:16:09 PM »
Yes it is cooldude
Colin
VRCC Espana
My Bumble Bee re-build
vanagon40
Greenwood, IN
« Reply #2 on: November 23, 2010, 06:58:08 AM »
Yes and no.
With my 2001 Standard, the auxiliary connection is off when the key is off and on when the key is on.  But it is not exactly like the headlight in that it does not turn off when the starter button is pushed.
Flat6Valk
Blacklick, Ohio
« Reply #3 on: November 23, 2010, 08:02:48 AM »
same as vanagon40.  That is something to consider when tapping into that circuit.
Alaskamike
gittin her done!
Wasilla, Alaska
« Reply #4 on: November 23, 2010, 03:11:04 PM »
Thanks guys... that helps!
