September 12, 2025, 11:35:42 PM *
Author Topic: Kickstand pad  (Read 925 times)
GREENDRAGON
Ft. Collins, Co.
« on: November 29, 2010, 03:40:42 PM »
RedValk, I got your message but it wont let me respond. E-Mail me or call me.
6packvalk@comcast.net - 970-692-9361.
GREENDRAGON
RedValk
Titus, AL
« Reply #1 on: December 07, 2010, 02:13:29 PM »
i took someone's idea...and had some 3/8 inch steel plug welded to the bottom of her stock foot. it works perfectly! ok, only one issue. The BRAND NEW stock spring for the valk i bought...when i put it on the stock kickstand (with the welded plug)...it's a tiny bit TOO long. So, it doesn't quite have enough tension to hold it FULLY retracted. So, i'll have to bend one end and shorten the spring a little. Another project for another day.............
but the height of the bike on the stand now .....is perfect!
RedValk/Tim
Titus, AL
Six Guns
Fort Worth, Texas
« Reply #2 on: December 07, 2010, 02:19:15 PM »
I bought a kickstand pad from Rivco for a VTX 1800 and it fit without me having to do any grinding. Used a rubber mallet to tap it in and put the set screw in. Worked like a charm.       cooldude
9Ball
« Reply #3 on: December 07, 2010, 02:26:35 PM »
You're welcome...... cooldude
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
« Reply #4 on: December 07, 2010, 05:12:13 PM »
P I C T U R E S      of the final result please.
Tanx.
Momz
ABATE, AMA, & MRF rep.
« Reply #5 on: December 07, 2010, 07:05:29 PM »
Kickstand is the guy in the denim jacket.
But I'd think he'd not take kindly to be used as a pad.
ALWAYS QUESTION AUTHORITY!
