August 02, 2025, 06:12:15 AM
vibration while cornering
Topic: vibration while cornering (Read 2994 times)
boppa
Rome, Ga
April 02, 2009, 06:15:03 PM »
lately i have noticed a vibration while cornering or leaning into a curve. the vibration is not there when riding in a upright position. any sugestions on where to start looking for the cause. thanks.
Disco
Republic of Texas
Re: vibration while cornering
April 02, 2009, 06:20:13 PM »
How many miles on your tires?
22 CRF450RL, 19 BMW R1250RT
78 CB550K
71 Suzuki MT50 Trailhopper
VRCC 27,916 IBA 44,783
April 02, 2009, 06:26:52 PM »
If the vibes are in a left turn, It's the left rear wheel bearing. If it's more of a hum up through the handlebars, it's the tire tread as the other post said. Tire tread noise is normal.
boppa
Rome, Ga
April 02, 2009, 06:51:14 PM »
less than 1000. vibration happens in left and right situatiions.
Momz
ABATE, AMA, & MRF rep.
April 02, 2009, 07:48:32 PM »
Check your tire pressures. My 2K I/S used to do the same untill I found the correct pressure values. Use the pressure values on the tire sidewalls not what Honda recommends.
ALWAYS QUESTION AUTHORITY!
Jean the Black Wolf
very proud to be a Valkyrie rider
France
April 03, 2009, 01:03:32 PM »
I think it's your rear tire
I had the same problém 2 years a go in Poland
Size does matter...........Aouhhhhhhhhhhh!!!!!!
Reply #6 on:
April 03, 2009, 02:17:17 PM »
oem dunlop tire, its the tread pattern.
=> InZane XXV
