May 02, 2026, 09:20:24 PM *
Author Topic: right side panel/ auxillary port  (Read 1544 times)
jimnvalk
Four wheels move the body, 2 wheels move the soul
Van, Texas
« on: December 19, 2010, 07:13:21 AM »
I have a 99 IS and the front clip on the right side panel is broken off.  Any suggestion on how to secure it so I do not accidently loose it?  Also how is the easiest way to mount an auxillary power to run my GPS and where do you recommend mounting it?
Jim
Let the Fun Begin.
99 Valk
98 magna-sold
Jim
MOOT #610
VRCC #30250
grizs50
Quinlan TX
« Reply #1 on: December 19, 2010, 08:19:00 AM »
Duct tape, You know what they say? If you can't Duct it, Chuck it!!! 2funny
VRCC #15503 "ONCE YOU'VE HAD A FAT LADY, YOU CAN NEVER GO BACK!"
15 minutes on a harley don't make you a biker!
"The Government is not your Mommy!"
Disco
Republic of Texas
« Reply #2 on: December 19, 2010, 08:31:56 AM »
You'll probably find several side / center cover repair suggestions by searching the Tech Board.  If replacement of the side cover is in your future, the good news is that side covers are MUCH easier to replace than the center cover, and typically more plentiful - especially black ones.
I ran with black electrical tape holding my RH side cover on for a long time.  A better (and possibly permanent?) solution is velcro.
My GPS power is run off the switched side of an auxiliary panel I installed under the RH side cover and goes up to the permanent mount.  My cigarette lighter adapter comes off the unswitched side of the same auxiliary panel.  The female end is mounted under the fuel selector on one of the engine hangers.  Another search of the Tech Board will produce more than you want to read about auxiliary power panels.  There are lots of good ways to do it.
22 CRF450RL, 19 BMW R1250RT
78 CB550K, 07 Helix
71 MT50 Trailhopper
Wanderer
The Great Republic of Texas - Dallas
« Reply #3 on: December 19, 2010, 08:58:34 AM »
I have done this fix a couple of times with staples melted into the plastic and JB welded over that, sculpted to perfection with a dremel.
Here is one post courtesy of RatDog...
http://www.vermin-club.org/mods/side_cover_tab_repair.htm
My variation along this theme used a wide crown finish staple. Lighter gauge, easier to bend and to melt into the plastic. Sure helps having a spare pair of hands to help and I would be glad to walk you thru the fix if you are in this neck of the woods.
The search engine really sucks on these type forums. Better to use Google - something like this link...
site:www.valkyrieforum.com side cover repair
I am sure Dan'l can chime in with a syntax that will show html, but this will get you on the way. ~Jeff
More Valk Pics...
had a couple of Valks once upon a time
2004 DRZ400S
2005 GS1200
1978 CB550K
1977 CB550F
« Reply #4 on: December 19, 2010, 10:00:27 AM »
If it is a clean break and you have the busted off piece, I bet you could fix it with ABS glue from
Lowes... here's pictures of how I fixed one of my side covers, it has held for about three years now...
You won't have two things glued together, rather the "glue" is a solvent and they'll be one
piece again... (that's how I understand it...)
Most of the glue types around here only work on PVC, since that is the prevalent kind of DWV pipe, so
if you try it, make sure it says ABS on the can...
http://hubcap.clemson.edu/~hubcap/d.sidecover/
john
tyler texas
« Reply #5 on: December 19, 2010, 10:22:58 AM »
i think i'll do the staple and glue just for the fun of it ...
reinforcement against breakage ...      Smiley
i don't take the covers off unless i need in there ...
and very gently ...     coolsmiley
i never need in there ...     ???
vrcc # 19002
