February 01, 2026, 04:12:39 PM *
Author Topic: Hand Grips  (Read 1524 times)
Garfield
97 Standard
Phoenix, AZ
« on: December 31, 2010, 01:09:59 PM »
I'm putting on new Kuryakyn hand grips and they are longer then the oem ones I took off. I seem to remember seeing somewhere about making some pvc end caps. Any suggestions? Do I really need the end caps?
« Last Edit: December 31, 2010, 01:21:51 PM by Garfield » Logged
Red Diamond
Beaumont, Texas
« Reply #1 on: December 31, 2010, 02:33:29 PM »
No you do not.
« Reply #2 on: December 31, 2010, 05:47:00 PM »
When I bought my kury flame grips they came with a couple pieces of pvc-like material designed for spacers.....drop them in the grip before installing. However I didnt need them, fit perfectly.  lube them up with some rubbing alkeehol to test fit, they will slip on and off easy as pie and then the alkeehol will dry and there is no mess
