February 01, 2026, 04:11:59 PM *
Author Topic: torque specs  (Read 4220 times)
f6rider
« on: January 07, 2011, 10:16:53 AM »
can someone provide with the torque specs for the Rotor bolts front and rear for a 2000 Tourer?
John
Kaiser
Gainesville, FL
« Reply #1 on: January 07, 2011, 10:47:09 AM »
14 lbf/ft. for the front and 31 lbf/ft. for the rear.
« Last Edit: January 07, 2011, 10:49:22 AM by Kaiser » Logged
« Reply #2 on: January 07, 2011, 10:48:22 AM »
The Honda book says R-31ft lbs and F14ft lbs.  However that is for a new bolt with the dry locktite on it.  If you use wet loctite those values may be a tad high, especially the rear.  When I did my rear some felt good at 31 some felt way tight so I stopped at 29 or so
f6rider
« Reply #3 on: January 07, 2011, 10:48:57 AM »
 thanks that is just what I am looking for !!
« Reply #4 on: January 07, 2011, 11:53:59 AM »
Have to be extremely careful when bolting into aluminum.
There is little to none early warning that the threads are going to let go,,, and the worst part is: That the threads to rip are always in the aluminum!
Torque wrenches are notoriously famous for being out of calibration (up to 10%) for any number of reasons.  So the lower torque values you may seek combined with a 10% error in the wrench can spell doom.
Good common sense and a good mechanical practice will always help in these tightening matters!
f6rider
« Reply #5 on: January 09, 2011, 08:21:40 PM »
the previous owner put new gafler rotors on and he polished the rotor bolts. That removed the coating and they rusted. So I replaced them with new.
Thanks,, I am searching for a used hondaline manual
thanks
ptgb
Youngstown, OH
« Reply #6 on: January 10, 2011, 05:13:45 AM »
...I am searching for a used hondaline manual...
http://www.valkyrienorway.com/download.html
« Reply #7 on: January 10, 2011, 10:10:31 AM »
I've posted this one a few times. Here is a post I did on another forum, gives the contact info for an online purchase I made for a Valk service manual, I was happy with it all.
http://hondashadowacetourer.yuku.com/topic/12127/Service-Manual
f6rider
« Reply #8 on: January 11, 2011, 04:05:14 AM »
thanks for all the good advise!!  I downloaded the manual from our norway brothers!
John   from Holland Ohio
« Reply #9 on: January 11, 2011, 11:24:38 AM »
John
John, pick your size and thread pitch and go for it.
This is what we use at the shop on unknowns.
http://www.cncexpo.com/MetricBoltTorque.aspx
