September 13, 2025, 02:01:46 PM *
Author Topic: short antenna  (Read 1036 times)
shank
Morristown TN.
« on: January 09, 2011, 05:39:42 PM »
Where can I find a short antenna for my Valkyrie I/S?  Just need one for the radio.
AussieValk
Gold Coast, Australia
« Reply #1 on: January 09, 2011, 06:00:32 PM »
any auto spares shop should have one of those short flexible ones. That's what I put on mine.
Valkahuna
DeLand, Florida
« Reply #2 on: January 09, 2011, 06:47:03 PM »
Is the reception as good as with the stock long one? On my H-D the short rubber one was a big loss in signal from the standard long one. Sad
2014 Indian Chieftain
2001 Valkyrie I/S
AussieValk
« Reply #3 on: January 09, 2011, 07:51:09 PM »
I haven't noticed any difference, mind you, I usually have the MP3 playing and only occassionally use the FM radio anyway.
Valkahuna
DeLand, Florida
« Reply #4 on: January 09, 2011, 07:59:34 PM »
I guess it is a choice of form over function, like just about everything else in life. Undecided
2001 Valkyrie I/S
PhredValk
Edmonton, Alberta, Canada
« Reply #5 on: January 09, 2011, 09:18:02 PM »
My IS came with a short black one. Gets FM farther out of town than my cage does.
Fred.
VRCCDS0237
Black Pearl's Captain
Emerald Coast
« Reply #6 on: January 09, 2011, 09:38:21 PM »
How short do you want? When I Super Valk my I/S I just put a 2' wire on the end of the connector and loop the wire around a bit under the side cover. Nothing showing on the outside.
Works fine, receiving antennas will work with just a bit of wire.
Raymond
Marcel
« Reply #7 on: January 10, 2011, 04:18:44 AM »
Lucky 13 cut his off on the last bike he had and just screwed on a chrome acorn nut over the end for safety and looks.
I was about 2 feet long at most and seemed to work fine.
Hacksaw
acorn nut.
pretty cheap and worth a try.
He did say it worked pretty well and could not tell a real difference.
« Last Edit: January 10, 2011, 07:44:10 AM by Marcel » Logged
chip
« Reply #8 on: January 10, 2011, 07:46:49 AM »
                                                 You could make it invisible
                    http://www.valkyrieforum.com/bbs/index.php/topic,22903.0.html
Emerald Coast
« Reply #9 on: January 10, 2011, 11:33:41 AM »
OK my last rant on this, that invisible (I can see it?) is nothing more than a wire going each way inside a plastic tube.
What's the difference between and inside a tube or a wire under your fairng or side cover. It's just a wire!!!
Spend your money on something that matters. Receiving antennas are JUST A PIECE OF WIRE no matter how you package it.
Raymond YMMVwildy.
« Reply #10 on: January 10, 2011, 11:55:20 AM »
Raymond YMMVwildy.
Raymond, save your breath.
Tell, or inform em once and forget it.
They no want to listen, that is their problem not yours.
Later Bro.
PharmBoy
Lawton, Ok
« Reply #11 on: January 10, 2011, 12:05:05 PM »
B.J., it is easy to do if you have the right supplies and a few tools, but it is hard to explain.  I'll try.  First, I took the antennae mount off the bar (2 bolts), then disconnected the antennae wire(unscrew from the bottom).  Now that it is off the bike, unscrew the keeper on top that lets the antennae tip over.  Inside there is a 1/8" pin that the OEM antenna hinges on.  Drive out that pin to disconnect the long antenna.  Now I am assuming that you have purchased the same antenna that I posted a picture of with name & number.  Disassemble that antenna.  Inside you will find a little rod with a spring that slips over it.  One end of that little rod needs to be shaped the exact same size as the end of the OEM antenna, except the end should be left SQUARE instead of rounded like the OEM antenna.  That little rod needs to go back in the slot where the end of the long antenna was attached by the 1/8" pin.  When you file it down where it fits tightly in the bottom of that slot without any slop on the sides, then clamp it down while fitting all the way against the bottom of the slot and drill a 1/8" hole through it using the existing holes in the female piece as a guide.  A good fit with the file and the drill is what keeps the new antenna from wobbling at the base.  Now, you will have to calculate how much to cut off the other end of this rod because I do not remember.  The rod needs to be long enough to support the spring, yet not too long to keep the new antenna from bottoming on the base where the OEM antenna keeper screwed on.  I believe that I determined the amount to cut off the other end of the little rod by putting the new antenna over he little rod while shoved to the bottom of the slot and measuring the distance from the bottom of the new antenna to where it should fit on the OEM base.  Then add another 1/8" or so and cut that amount off the little rod.  Also file or grind off the sharp edges of the little rod after cutting it off so the spring won't get hung on them.  The spring must be placed over the rod to conduct the signal from the inside of the new antenna to the antenna wire.  Now, you will need a 1/8" rivet that is at least 0.7" long.  A 1/8" piece of brazing rod cut to 0.7" will work fine. The 0.7" rivet must reach all the way through the base of the new antenna and be bradded (not now) with a small ball peen hammer(slowly).  Now you need to drill a hole in one side of the base of the new antenna exactly 0.3" up from the bottom of the base.  The size of this hole should be less than 1/8" because the plastic base of the new antenna needs to fit tightly around the 1/8" rivet on both sides.  A #35 drill (0.110") is ideal if you have one, can borrow one, or even buy one.  Now, with the hole drilled in one side of the base of the new antenna, place it over the OEM base and using the existing holes in the slotted OEM base, run the drill bit through those holes and drill a hole in the other side of the new antenna base.   Now all that is left to do is assemble all this at once.  Sounds easy, but an extra hand or two really helps.  I put just the smallest amount of J B Weld on the inside of the new antenna base to make sure that it fit well. Put the short rod in the slot with the holes lined up (if you made it a tight fit, it  will stay) slip the spring over the rod and push the new antenna down on the base with all the holes lined up and push the 1/8" brass rivet through all the holes that you have drilled, from one side to the other.  You might now temporarily hook up the antenna wire and check to make sure that you are getting a signal to the radio while you can still get it apart.  If it works, remove the antenna wire and gently brad the rivet on both sides with a small ball peen hammer working on one side and then the other until it has been spread enough that it will not come out from either side.  A little dab of black paint on each end of the rivet and you are ready to reconnect the antenna wire and mount your new antenna on your bike.  Before I went to all this trouble, with the bike in the garage, I tuned in a marginal FM station and switched antenna signals back and forth between the new antenna and the OEM antenna.  The short antenna gave the best signal by the slightest of margins.  My neighbor was there at the time and he concurred with my opinion.  Yes, I could have had your new antenna on your bike in less time than it has taken to write up the procedure.  However, it sure took a lot of thinking before I figured out how to put mine on.  B.J. I hope that this helps.  Oh yes, if you use any JB Weld, use only the smallest amount, because too much could short out the signal.  Also, if you have or can borrow a dial caliper, it sure helps in making accurate measurements.  Send me a picture!...Jim Lynch
4th Infantry Tet Vet
99 Interstate
97 Bumble Bee
97 Red & White
