November 22, 2025, 07:40:13 AM *
Author Topic: How do you  (Read 2089 times)
busser
« on: January 14, 2011, 04:12:37 PM »
get ALL of the gas out of a standard gas tank? TIA Busser
Red Diamond
Beaumont, Texas
« Reply #1 on: January 14, 2011, 04:19:14 PM »
Pull the petcock.
« Reply #2 on: January 14, 2011, 04:29:35 PM »
Take it off and dump it out ....Excellent time to service the air filter.
busser
« Reply #3 on: January 14, 2011, 05:37:32 PM »
I've taken out the petcock, turned the tank upside down, side ways, right side up, and still there is gas in the tank. Is there a baffle inside? TIA Buss
BamaDrifter64
Athens, Alabama
« Reply #4 on: January 14, 2011, 05:44:46 PM »
Guess you could light a match and stick it in the tank to see where that gas is staying at....JUST KIDDING!!!!   2funny
Dave
« Reply #5 on: January 14, 2011, 06:05:37 PM »
Do you have access to compressed air?   Hang it up with open holes, it will evaporate eventually.
John U.
Southern Delaware
« Reply #6 on: January 14, 2011, 07:30:00 PM »
Acetone will clean out sludge and the remainder will evaporate quickly. Keep it off paint.
alph
Eau Claire, WI.
« Reply #7 on: January 15, 2011, 05:49:19 AM »
I got a large syringe with a 24” rubber tube, stand the tank on end, and suck the fuel out.   I do this every year, and still am amazed at the crap I find in the bottom!!
You can get a large syringe from Wal-Greens, or any pharmacy.  Rubber tubing from any auto store……  I have done this with the tank on the cycle, but I still feel that having the tank off the bike, and standing on one end so all the fuel goes to one corner is the easiest.
busser
« Reply #8 on: January 15, 2011, 09:54:08 AM »
Thanks!!! That was what I was looking for. I support your "world peace" solution. Busser
fat6man
Crystal City, Missouri
« Reply #9 on: January 16, 2011, 03:32:34 AM »
Drilling 10 - 15  1/4" holes in the lower areas of the tank might do the trick also...
                                                      2funny
Rastus
« Reply #10 on: January 16, 2011, 08:02:21 PM »
Drive as far from a gas station as you can. You will empty your tank.   Grin Grin
« Reply #11 on: January 16, 2011, 11:30:42 PM »
I do the same - and use a length of surgical tubing - neoprene - to fish into the bottom corner and siphon the last out.  I also have a suction device that will suck on a hose when it's hooked up to compressed air - use that while wiggling the hose in the tank to collect what might be missed while siphoning.  Then put in a piece of durable, absorbent paper toweling - the kind that holds together meant for reuse - wad it up, put it in the tank to absorb what remains - and of course, remove the wad.  Then if I need it to be vapor free - put a hose in it hooked to my low-pressure regulator I use for airing my powdercoater - regulated at 10 lbs.  Let that blow air into the bottom of the tank for 10 minutes.  After that - I can't even smell gas in the tank. At this point, I'm ready to weld on the tank.  But I still wait a while for more airing out.  Superstitious probably.
