March 21, 2026, 01:29:40 PM *
Author Topic: General Altimax  (Read 2042 times)
Tundra
2014 Valkyrie 1800
Seminole, Florida
« on: January 15, 2011, 05:35:07 AM »
I want to try a 65 series, currently running a 60 series. To those of you running  the "Altimax" do you like it? Would you buy it again? I LOVE that tread pattern.
MP
North Dakota
« Reply #1 on: January 15, 2011, 06:11:58 AM »
I have two Valks on the Altimax.  Like them a lot.  Better than the Hydroedge.
MP
"Ridin' with Cycho"
wizard -vrccds#125
Hitchcock Tx.
« Reply #2 on: January 15, 2011, 06:53:02 AM »
Im on my 4th Altimax, with 2 new ones on the shelf. Im not going to change !     uglystupid2
Tundra
2014 Valkyrie 1800
Seminole, Florida
« Reply #3 on: January 15, 2011, 07:05:51 AM »
Which are you using, the 60 or the 65?
wizard -vrccds#125
Hitchcock Tx.
« Reply #4 on: January 15, 2011, 07:14:32 AM »
Tundra; it no longer comes in a 65 so I run the 60.      cooldude
Jabba
VRCCDS0197
Greenwood Indiana
« Reply #5 on: January 15, 2011, 08:50:18 AM »
I do not like my altimax as much as my Falken.  It's a lot more demanding of EXACT tire pressure to not feel queer.
I will not be buying another one.
Jabba
Tundra
2014 Valkyrie 1800
Seminole, Florida
« Reply #6 on: January 16, 2011, 05:21:27 AM »
Wizard, I found the Altimax in a 65 series, however the tread pattern is differant than the 60 series. I don't know if I like the looks of it???
General Altimax 60 series, real nice deep grooves along the sides.
This is the Altimax 65 series  ??? Not so sure about it?
  Some other contenders in the 60 series. I don't care for the Tripple Tread, other than it won't wear out. It's a very flat, squared off tire.
Goodyear Tripple tread
Bridgestone Potenza 60 series
Never saw this before, looks pretty good
Yokohama Envigor...It appears to be more rounded than the others?
I would like to go up to a 65 series, most of them start turning into "Grandma's Buick tires" as SmokinJoe has stated.
« Last Edit: January 16, 2011, 05:39:50 AM by Tundra » Logged
alph
Eau Claire, WI.
« Reply #7 on: January 16, 2011, 05:44:02 AM »
i like the looks of that Bridgestone tire!!  and as for grandma's tire, becareful, there are some "GILF's" out there!!! Wink
Tundra
2014 Valkyrie 1800
Seminole, Florida
« Reply #8 on: January 16, 2011, 05:51:29 AM »
Yikes...no GILF'S for me
Tropic traveler
Silver Springs, Florida
« Reply #9 on: January 16, 2011, 06:41:37 AM »
Doug, stay away from the Michelin HydroEdge. Maybe it's a great car tire but squeezed on a Valk rim it's as square as a brick. Hafta run 28 psi just to get acceptable low speed handleing.
God please give us a 195/70/16 tire with a rounded edge!  Cool
Haven't found one yet!
'13 F6B red for Kim
Bob E.
Canonsburg, PA
« Reply #10 on: January 16, 2011, 08:48:17 AM »
I run the Altimax 60-series.  This is my first car tire and it's fine...although I don't have experience with others.  I did find that it needs higher pressures than what some are running in CT's. I started off at 35psi, then went to 32 based on what alot of others were saying.  I found at these lower pressures, I would get a wiggle/sway/fishtail in longer high-speed sweepers like on the interstates.  Raising the pressure up to 42 or so eliminated that issue, but also increased the squareness feel a little.  I'll need a new tire to start the riding season and I'm really torn between a new Altimax or going back to a MC tire.  The CT netted about 12,000 miles and could go a couple thousand more, but I got a flat at the end of the riding season last year.  I plugged it, but it still has a slow leak that I need to add air every other day.  At half the cost of a MC tire, it's definitely a better bargain.  So I'll probably buy another one here in the next month or so.
wizard -vrccds#125
Hitchcock Tx.
« Reply #11 on: January 16, 2011, 10:04:00 AM »
Tundra; the 65 altimax does NOT apear to to be same tread from right to left (not a directional tread) That is why im not running it !
« Last Edit: January 16, 2011, 11:00:18 AM by wizard -vrccds#125 » Logged
Tundra
2014 Valkyrie 1800
Seminole, Florida
« Reply #12 on: January 16, 2011, 03:33:51 PM »
Yup, agreed  cooldude
Thunderbolt
Worthington Springs FL.
« Reply #13 on: January 16, 2011, 05:33:45 PM »
225/60-16.  It doesn't have near the miles that I do on the Bridgestone HP550 on the Valk, it's a 205/60-16, it has around 11000 and still going strong.  I like Eddies idea from lunch the other day.  He said he knew someone that could shave the edges.  If I knew someone around here, I would give that a shot to make it more rounded.
Dogg
Berlin Md
« Reply #14 on: January 16, 2011, 10:54:29 PM »
Id have to check my tire size. I dont think Im near the size you guys run. I think mine is a 205 55 16
Dogg
Berlin Md
« Reply #15 on: January 16, 2011, 10:56:13 PM »
Ill look at the size tomorrow
G-Man
White Plains, NY
« Reply #16 on: January 18, 2011, 07:45:06 AM »
Hey Dogg, do those exhaust tips spin when the engine is running?
« Reply #17 on: January 18, 2011, 08:27:25 AM »
They sure do...
Hay  Cool
