February 01, 2026, 05:59:07 PM *
Author Topic: Fork oil change  (Read 2249 times)
Iroqouis
« on: January 25, 2011, 02:03:18 PM »
Like too change fork oil as its been about 6 years since I hade gold valves  and progressive springs installed. Is it possible to change fluid without fork removal also would anyone have recomendations on weight of oil to use. Im 230 shes about 150 also pull trailer. fairly agressive rider still would like somewhat nice ride. Hey thanks for your help!!
« Reply #1 on: January 26, 2011, 07:59:33 AM »
If there is no leaking there should be no need to mess with them.
If you remove the top caps it has been said you can siphon (vacuum) out the oil.
Doubtful that all the oil can be removed this way.
Again! Best to let sleeping dogs lay!
« Reply #2 on: January 26, 2011, 01:22:57 PM »
You can get suck most of it out, just don't add any more new fluid than you got out. I use 10 weight belray, but I ride solo at 170 pounds, you may want higher viscosity.  hoser
« Last Edit: January 26, 2011, 01:26:30 PM by Hoser » Logged
John U.
Southern Delaware
« Reply #3 on: January 26, 2011, 07:18:47 PM »
A heavier oil will stiffen the ride, so will adding more oil; air compresses, oil won't. You could measure the oil that comes out. Even if your measurement is shy because of oil clinging to the suction tube, you will have too little oil and the ride may be too soft. It's still easier to add a bit than remove it.
Steve K (IA)
Cedar Rapids, Iowa
« Reply #4 on: January 26, 2011, 11:25:49 PM »
I would agree with Ricky.  If it ain't broke, don't fix it.  Wait until you have to replace a seal...or two.  Wink
States I Have Ridden In
Iroqouis
« Reply #5 on: January 27, 2011, 09:49:39 PM »
sounds like good advice everytime I mess with something not broke I break it thanks  Iroqouis
