February 01, 2026, 05:55:15 PM *
Author Topic: rub marks on tire  (Read 3532 times)
slider
mulberry arkansas
« on: January 25, 2011, 03:18:51 PM »
rear tire on my valk has what appear to be rub marks on the outside edge of the tread area.iT HAS correct tire size,proper inflation,and looking up inside the fender well I can see no area that looks to be rubbing .The mark is smooth and almost shiny,what ever is rubbing is not actually cutting into the rubber ,just polishing it.I am at my wits end.Only thing I can think of is the shocks set to low.when my wife and I ride.Im 210 she is 110.The marks are equal on both sides and are about 2 inches wide.and run completly  around the tire  .Any suggestions???
a proud navy veteran
eric in md
« Reply #1 on: January 25, 2011, 03:55:18 PM »
slider   breathe i went thru that also come to find out the swing arm on the right side was rusted there is a thin stamped metal cover there that collects all the junk then rusts..  what i did was remove the rear tire and grind that thin metal stamp piece off then painted the swing arm again . no more problems
slider
mulberry arkansas
« Reply #2 on: January 25, 2011, 03:59:51 PM »
thats something I had never thought of,brother you can bet I will check it out tomorrow thanks so much for the info
Thunderbolt
Worthington Springs FL.
« Reply #3 on: January 25, 2011, 04:01:24 PM »
if this is a new problem and you haven't lowered the settings.
Bone
« Reply #4 on: January 25, 2011, 04:41:07 PM »
If the rub is on the sidewall make sure your air pressure gauge is OK. I had a car tire on the Valk that would show an occasional rub mark on one side and it was low air pressure. With the correct tire that probably isn't your problem. Cold air temps will drop the air pressure.
Brad
Reno, Nevada
« Reply #5 on: January 25, 2011, 04:45:11 PM »
If the marks are on both sides of the tire it can not be the swing arm.
eric in md
« Reply #6 on: January 25, 2011, 04:52:43 PM »
 cooldude  +1 brad your right only the right side will rub
« Reply #7 on: January 25, 2011, 05:10:15 PM »
Run your hand all the way around the fender inside, both sides.    I ran over a plastic bag a long time ago and it stuck, then dropped down over the edge of the tire.
Ken Tarver
North Mississippi
« Reply #8 on: January 25, 2011, 06:00:06 PM »
does the rear fender have the pieces of rubber glued to the underside like the front fender? my front had a rub ~ that rubber came loose and was rubbing the tire.
Ken
slider
mulberry arkansas
« Reply #9 on: January 26, 2011, 05:47:59 AM »
well guys I am really stumped,nothing under the fender is loose,jacked her up and rear tire has no side to side play,no up and down play nothing under the fender looks to be rubbing ,shouck gromewts are new(replaced in the fall) so am going to raise the shocks a couple of  clicks and see what follows....thanks for all the tips so far any others will sure be welcome..hate to ruin a new tire....also could be dangerous
Kaiser
Gainesville, FL
« Reply #10 on: January 26, 2011, 07:09:46 AM »
I doubt it is this - but any chance it's the nut cage inside the rear fender?
http://lifeisaroad.com/stories/2005/08/24/valkyrieRearFenderNutCageMod.html
olddog1946
Moses Lake, Wa
« Reply #11 on: January 26, 2011, 07:12:02 AM »
My neighbor and I go riding every chance we get, as long as there is no snow/ice on the road..both of us are having that type of "rubbing" show up on our bikes..it IS NOT actual rubbing of the tire, it only shows up on the right hand side of the tire, much easier to see on the front..I can find no mechanical reason for it...I believe it is coming from the stuff on the roads. though I have no idea why it would only be on one side not both..must have something to do with the crown of the highway..since we've had snow, roads treated, etc..I have noticed it after every ride..
« Last Edit: January 26, 2011, 07:16:30 AM by olddog1946 » Logged
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
MP
North Dakota
« Reply #12 on: January 26, 2011, 07:41:20 AM »
+1
I had to go to carraige bolts from the inside out to stop it.
MP
"Ridin' with Cycho"
« Reply #13 on: January 27, 2011, 08:28:04 AM »
I cannot comment on front tire rubbing.
However rear tire rubbing can occur under certain circumstances.
I am only addressing rubbing on the swingarm.
Because of manufacturing practices the swingarms are all a little different from each other. In some instances the tire may run close to the swingarm.
If you run an oversize tire, or a car tire the distance between the tire and the swingarm can be even less than design.
When you lift the bike you may find clearance and then confusion occurs since the rubbing is actually happening but you cannot find it!
The reason for this rubbing is due to the tire tread moving off center during cornering resulting in the sidewall rubbing on the swing arm. Straight line running will not cause rubbing.
The sidewall construction and sidewall stiffness directly relate to the rubbing. Air pressure in the tire can have some effect on the rubbing but is not necessarily the cure all.
Loading has no effect on this rubbing.
Remember that I am only referring to the tire rubbing on the swingarm.
« Reply #14 on: January 27, 2011, 09:25:21 AM »
I guess I got lost on this topic.
I thought someone said it was shiny type rubbing, not digging into the type type.
Could someone fill me in here please?
Thanks.
slider
mulberry arkansas
« Reply #15 on: January 27, 2011, 11:00:00 AM »
yes the areas that appear to be rubbing are very slick and shiny there appears to be no damage to the rubber of the tire,and i dont hear any strange noises..im lost just one of those strange things going on..thanks to everyone..when i find the solution i will post it,,
aslondon
VRCC #4321
Monticello, Fl
« Reply #16 on: January 27, 2011, 11:30:59 AM »
Is it maybe the wiring harness up inside the fender is loose and the tire is lightly rubbing on it.  There is definitely a wire bundle running up the right side which houses the brake and turn signal wiring.  Worth checking to see if it came a little loose.
Sorry I re read the original post and did not notice that you said on both sides I think that harness is only on the right side.  Are you talking about the area on either side of the flat spot the runs down the middle of the tire?
Al
vrcc 4321
« Last Edit: January 27, 2011, 11:36:56 AM by aslondon » Logged
Baloo
Rimouski, Canada
« Reply #17 on: January 27, 2011, 11:43:00 AM »
As the old man said: a few photos are worth a thousand words... any available?
Never ride any faster than your guardian angel can fly...
slider
mulberry arkansas
« Reply #18 on: January 27, 2011, 03:13:06 PM »
cant seem to get pictures to load on here,if anyone wants to see what the problem area is send me a pm and will send pictures,thanks again for all the helpful hints,,
slider
mulberry arkansas
« Reply #19 on: January 28, 2011, 12:18:37 PM »
thank s to all of you who posted the help hints--esp thanks to RJ-the mystery has been solved--removed rear tire as RJ suggested to check the swing arm and there was a part of a mud flap ,I assume off an 18 wheeler wedged into the frt upper part of my fender and I guess when I hit a bump it would make contact with the tire sides. thanks again for all the help!!
Baloo
Rimouski, Canada
« Reply #20 on: January 28, 2011, 12:23:45 PM »
Great  cooldude Congrats on finding it! Now you're left with the hard part of the job: ride it like you stole it!!  Wink
Bone
« Reply #21 on: January 28, 2011, 01:17:34 PM »
I was close in my thoughts but didn't post. I wondered if you had parts of an Armadillo stuck in the fender well Smiley
Glad you solved the mystery.
eric in md
« Reply #22 on: January 28, 2011, 01:28:51 PM »
 cooldude  glad you found it .. strange huh
Ken Tarver
North Mississippi
« Reply #23 on: January 29, 2011, 06:26:01 PM »
hey you just got a free accessory
slider
mulberry arkansas
« Reply #24 on: January 29, 2011, 06:33:51 PM »
left the free mud flap at home today and took the bee  out for a test run,drove scenic 71 to fayettvill arkansas and had luch with  a friend..beatuful ride..my boss /wife went along just to keep me out of trouble--glad to say the rub marks did not appear thanks to you all for your help!
