February 01, 2026, 05:58:45 PM *
Author Topic: Another alternate Alternator Cover question ....  (Read 3746 times)
Sodbuster
« on: January 25, 2011, 06:29:45 PM »
Anyone know if this cover would work/fit in place of OEM ??
It is a coil cover for a 84 -99 SOFTAIL H-D (I don't know the dimensions)
VRCC # 30938
Ken Tarver
North Mississippi
« Reply #1 on: January 25, 2011, 09:01:42 PM »
good question ~ I may need to know that also
Ken
Shockbushing Gary
« Reply #2 on: January 26, 2011, 07:51:51 AM »
Not really, in the sense of a bolt-on.
Take your alternator cover off and look at it. It is secured in an unusual and trick way. It snaps on a rubber grommet on one side and a bolt holds it at the bottom.
I made a few of these when my alt cover crazed. This one was chromed at a local shop. I have just a couple left, unfinished. They can be painted, chromed, whatever. All steel, no plastic.
« Reply #3 on: January 26, 2011, 07:55:11 AM »
That Harley coil cover is quite a bit smaller than the Honda alternator cover.
« Reply #4 on: January 26, 2011, 11:13:21 AM »
Even if you could get it to fit.......(I mean it looks good and everything) how much would that HD part slow your Valkyrie down?
ricoman
Sarasota, FL
« Reply #5 on: January 26, 2011, 11:40:27 AM »
odds are, using it would cause 4 cylinders to quit!
us385south
"Geeky White Caucasion"
San Marcos, Texas
« Reply #6 on: January 26, 2011, 01:08:15 PM »
I'm confused!  I know the chrome bubbling up on those was an issue but why not just buy another OEM part?  They're not THAT expensive.
"I can't explain a blessed thing,
not a falling star or a feathered wing,
but when the light's just right I swear I see...
poetry!"
« Reply #7 on: January 26, 2011, 01:18:05 PM »
I guess we just dream of replacing those three plastic covers with "real" covers... no vendor (that I know of) ever made a "real" cover for
the alternator...
So Gary did it himself...
Sodbuster
« Reply #8 on: January 26, 2011, 03:48:36 PM »
Yup .... I realize it's not a direct bolt-on and am familiar with how it attaches to the bike. I was just thinking of something cheap to start with (< $10 on flea bay) and modify it to attach to the bike.
Just thinking outside the box to come up with something that will last longer.  A new one is $36 and some change @ HDL.
I was thinking of bringing mine into work and have a machinist mill some slots in it to help dissipate the heat ??
Also, how hard is it to remove the chrome for painting ??
Anyway, do appreciate the feedback
Sodbuster
VRCC # 30938
Tropic traveler
Silver Springs, Florida
« Reply #9 on: January 26, 2011, 06:47:41 PM »
Find a way to strip the chrome from the bad one & paint it. I did that on the '99. I didn't have to strip it as it already was when I got the bike. Maybe a careful glass bead job would do it?  Painted it with semi-gloss black & bolted it back on.
I can be a cheapskate sometimes! Smiley
'13 F6B red for Kim
« Reply #10 on: January 26, 2011, 09:34:16 PM »
I was thinking the same thing. Reverse electrolisis, an acid bath and a battery (charger) and see if we can strip the chrome from it.
Then either spray chrome or just color match to the rest of the bike.
« Reply #11 on: January 27, 2011, 08:09:18 AM »
The cover is plastic!
The reason the chrome plating wrinkles and buckles is the base material (plastic) is shrinking.
The chrome is a pretty thick layer and will peel off quite easily.
Screw it! I just leave it alone and accept it.
valkmc
Idaho??
Ocala/Daytona Fl
« Reply #12 on: January 27, 2011, 07:06:20 PM »
Here is Gary's simply painted black.....
2013 Black and Red F6B (Gone)
2016 1800 Gold Wing (Gone)
1997 Valkyrie Tourer
2018 Gold Wing Non Tour
Sodbuster
« Reply #13 on: January 27, 2011, 08:24:04 PM »
No disrespect to Gary's solution but I was looking for something that would be more rounded looking. My cover doesn't looking bad at all right now but just thinking ahead.
VRCC # 30938
valkmc
Idaho??
Ocala/Daytona Fl
« Reply #14 on: January 28, 2011, 08:30:08 AM »
After I put Gary's on I strip my old one and painted it black. It came out good and was not very difficult. I am hanging on to it just in case.....
