February 01, 2026, 05:55:11 PM
Brake Light wire Help
Topic: Brake Light wire Help (Read 1537 times)
Garfield
97 Standard
Phoenix, AZ
January 26, 2011, 05:09:22 PM »
I got a new license plate with brake and running lights on it. What wire is what on a 97 Standard brake light? I've tried looking it up but I just can't find it. Thank You
1) Green?
2) Green and white?
3) It look like it is brown?
Re: Brake Light wire Help
January 26, 2011, 06:34:02 PM »
Before I removed the wires from the license plate, I compared what I removed from what it was plugged into, and they matched. That was an 99' IS.
Is the years matching on yours, why wouldn't the wire colors be the same?
Are you looking at the schematic of the wiring in the Service Manual?
Mr Steve
Feeding Hills, MA
January 27, 2011, 02:58:25 PM »
IIRC:
green/white - Brake
Green - Ground
Brown - Run
Garfield
97 Standard
Phoenix, AZ
January 27, 2011, 04:59:56 PM »
Thanks for the help
I should have posted last night that I found it
