February 01, 2026, 07:39:52 PM *
Author Topic: Front speaker bezel  (Read 2613 times)
xmicmic
« on: January 29, 2011, 05:07:08 PM »
Some time ago I asked a question about how to get the screws out of the front bezel that holds the speakers to to front shroud. I found out that they are lock tighted in. While taking out the screws, it twisted the threaded sleve or nut inside the front shroud out of it's hole. The solution was to put epoxy in the hole and re-insert the threaded sleve into the front shroud holes. Well to my suprize I could not break loose the threaded sleve off of the screw and the threaded sleve broke and now I will have to figure how to get the remaining broken sleve off the screw. The screws are available for purchase but can't find the threaded sleve that the screw is supposed to screw into. Anybody have any idea what to do. Thanks Mke.
Challenger
« Reply #1 on: January 29, 2011, 08:09:51 PM »
I believe the part #90316-MJ-000 is what you need, glue the new insert back in with JB Weld and never-seez the screw.
xmicmic
« Reply #2 on: January 30, 2011, 06:51:17 AM »
Thanks for the input. I went to my service manual and it didn't show that part at all so then I went to cheapparts.com and in their break down they didn't show it either. Thanksagain. Mike.
Challenger
« Reply #3 on: January 30, 2011, 08:14:10 AM »
If you type in fairing nuts in the Old Tech archives tab and scroll down to Valk I/S part number you will find that another member found the part#. It is not on any fische. It can be ordered by a Honda dealer. Hope this helps.
NJF6Cowboy
« Reply #4 on: January 30, 2011, 11:37:17 AM »
I can't seem to find the link.
Challenger
« Reply #5 on: January 30, 2011, 12:32:21 PM »
At the top of this page in gold, it says (Home page) (photostash) (just pics) (shop talk) Old tech archives) click on the old tech archives, on the right side of the page type in the search words, select all from the drop down box, search.
NJF6Cowboy
« Reply #6 on: January 30, 2011, 05:37:52 PM »
Challenger,
Sorry but on my screen its not there. Cry
NJF6Cowboy
« Reply #7 on: January 30, 2011, 06:03:15 PM »
found the link my screen page was reduced in size. Thanks for the help.
Six Guns
Fort Worth, Texas
« Reply #8 on: January 30, 2011, 07:08:59 PM »
When I did a search of the Old Tech Archives, the part # that I found for the brass inserts is 90316-MJ1-000. Not sure if your part # is right or mine. I'll call Honda Directline tomorrow and find out.
fordmano
San Jose, CA.
« Reply #9 on: January 30, 2011, 07:42:49 PM »
I am holding a bag of 10 packages of those inserts and the number on each individual package is 90316-MJ1-000 and the matching screw is 90107-MBY-000.
You are not the first to strip these out and surely won't be the last one either.
I managed to mess up 2 of them during my current project. tickedoff
Good luck and hope this info helps you out.
So now every other helping person can save their quarter on those phone calls to the Honda Dealerships. cooldude
83GS550
93XR650L TARD!
97WR250
99ValkyrieI/S Tri-tone
01YZ125(x2)
05DRZ-125
Challenger
« Reply #10 on: January 31, 2011, 06:11:19 AM »
Thanks Six Guns & Fordmano, I must have been typeing faster than my brain could proof read. I even had the correct # copied down. Sorry for any stress caused!
Six Guns
Fort Worth, Texas
« Reply #11 on: January 31, 2011, 04:27:18 PM »
No worries. All's good.   cooldude
