February 01, 2026, 07:35:06 PM *
Author Topic: Interstste Headlight housing replacement  (Read 1880 times)
Papa-Russ
Bremerton, WA
« on: January 30, 2011, 04:18:30 PM »
I need instructions for removing the headlight assembly, Not just the bulbs but the entire assembly.  I hace a 1500C repair manual but have not yet gotten one for my interstate.
Any help appreciated.
Papa-Russ
Kitsap County, WA
roboto65
Conroe,TX
« Reply #1 on: January 30, 2011, 04:32:59 PM »
http://valkyrienorway.com/download.html
Download that one that covers the IS also..
Allen Rugg
VRCC #30806
1978 Kawasaki KZ 650 project
Papa-Russ
Bremerton, WA
« Reply #2 on: January 31, 2011, 09:10:58 AM »
Thanks for the download, however it only covered the standard/tourer headlight removal.  It did cover the combination meter removal.  Has anyone replaced the heqadlight assembly?  Do I need to remove the combination meter first?
Thanks - Some mean person smashed my headlight lens' on my 99 Interstate and the cost for the replacement assembly isn't cheap.  $400+
Papa-Russ
Papa-Russ
Kitsap County, WA
shortleg
maryland
« Reply #3 on: January 31, 2011, 09:41:41 AM »
  Easyest way would be to remove fairing from bike.
Start by removeing speaker panels then unplug all
connecters, then four bolts holding on fairing.
      Shortleg[Dave]
« Reply #4 on: January 31, 2011, 09:42:17 AM »
You'll have to remove a lot to reveal the backside of the headlight bucket.
Remove the two panels that hold the speakers.
Remove the chrome bezel and windshield.
There are a few rubber mounted bolt that remain to be removed finally.
The fairing will then be able to rotate forward on the turn signal assemblies to reveal the innards.
A lot of caution is advised. Unclip the wires at the proper points.
The screws that hold the fairing parts together are a special problem and you should do some research on this specific item.
« Last Edit: January 31, 2011, 09:44:30 AM by Ricky-D » Logged
Joe Hummer
Arnold, MO
« Reply #5 on: January 31, 2011, 04:39:09 PM »
http://www.ronayers.com/Fiche/TypeID/26/Type/Motorcycle/MakeID/1/Make/Honda/YearID/40/Year/1999/ModelID/6791/Model/GL1500CF/GroupID/289240/Group/HEADLIGHT
1999 Valkyrie Interstate
