February 01, 2026, 07:40:49 PM *
Author Topic: Headlight replacement part # ?  (Read 2214 times)
Valker
Wahoo!!!!
Texas Panhandle
« on: January 31, 2011, 06:08:20 PM »
Gurus, does the Valk headlight use one of these for the complete unit?
Par 56, H6014, or H6024
X Ring
VRCC #27389, VRCCDS #204
« Reply #1 on: January 31, 2011, 09:05:16 PM »
The headlight uses a H-4 bulb.  I think in cage headlights it is a 9003.
Marty
Valker
Wahoo!!!!
Texas Panhandle
« Reply #2 on: February 01, 2011, 04:26:50 AM »
Sorry, I guess I wasn't clear. I need to know if one of those part numbers is for the WHOLE headlight unit, not just the bulb. I'm looking to know if these will work to replace the whole part that the bulb fits into (not the chrome shell). This is on a Tourer/Standard.
Number 9 in this picture: http://www.ronayers.com/Fiche/TypeID/26/Type/HEADLIGHT/MakeID/1/Make/Honda/YearID/39/Year/1998/ModelID/6597/Model/GL1500CT/GroupID/278112/Group/HEADLIGHT
shortleg
maryland
« Reply #3 on: February 01, 2011, 04:34:15 AM »
  Whole headlight 33100-MZO-671
   just the bucket  with reflecter 33120-MZO-671
           Shortleg[Dave]
Valker
Wahoo!!!!
Texas Panhandle
« Reply #4 on: February 01, 2011, 04:09:57 PM »
OK, it's official-I suck at explanations. uglystupid2
I am trying to replace my stock headlight with one of these LED units: http://www.truck-lite.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10001&storeId=10001&productId=64057&langId=-1
and need to know which one to order or if they would even fit to replace it.
Thanks again. Hopefully this explains it better. Wink
X Ring
« Reply #5 on: February 01, 2011, 10:00:28 PM »
Google, bing or any search engine can be your friend.  The PAR 56 is a train headlight.  The H6014 is a standard sealed beam incandescent headlight and the H6024 is a halogen sealed beam headlight.  Whether or not the kit you're looking at will work in a Valk headlight shell is anyone's guess.  Check their return policy.  If it's pretty good then buy it and let us know.  You could find the H6014 or 6024 headlight and try it in the Valk headlight shell to see how it fits.   Either way let us know how it goes.
Marty
Valker
Wahoo!!!!
Texas Panhandle
« Reply #6 on: February 02, 2011, 05:16:19 AM »
Thanks, Marty. Exactly what I was looking for...didn't even cross my mind to Google it!! Doh! uglystupid2
jad
N. Atlanta Ga
« Reply #7 on: February 02, 2011, 10:15:37 AM »
I thought that my Valk has a 9" light and the one in question is a 7".
Be sure to  check the diameter of the light fixture... to be sure.
How hard would it be to use a different shell to fit the 7" lamp?
I use the 9003 Sylvania along with my 55w running lights mounted way down low.
I'm also interested if there is a solution to the LED lamp.
John
98 Burg & Cream Tourer
Gangman036
Terre Haute, IN
« Reply #8 on: February 04, 2011, 05:10:04 PM »
Pulled from an earlier post on headlights.................
               Headlight Bulb
Headlight bulbIts called XTRAVISION 9003/H2/H4 by Sylvania. It costs half as much as the silver star one and its plenty bright. Last night Judy and I came home from the coast at night and I was well pleased with the "whiteness" and the brightness from shoulder to shoulder and depth of vision was greatly improved.
Ride Safe
X Ring
« Reply #9 on: February 04, 2011, 07:16:59 PM »
               Headlight Bulb
Ride Safe
Did you actually read the whole thread and discover that Valker is thinking about replacing his headlight with a LED unit or did you just read his first post and make an assumption?
Marty
