March 21, 2026, 09:28:03 PM
All You Mac Geeks Out There
Topic: All You Mac Geeks Out There (Read 1040 times)
Bama Red
Fayetteville, Tennessee
February 01, 2011, 08:20:07 PM »
The little widget called the "Dashboard", that has the calculator, WX forecast, clock and calendar...
How do you change the default settings on that puppy? It defaults to Memphis for WX forecasts and Calgary for the time. Neither of them help me much! ???
VRCC Member #32561
Garfield
97 Standard
Phoenix, AZ
Re: All You Mac Geeks Out There
February 01, 2011, 08:35:33 PM »
Quote from: Bama Red on February 01, 2011, 08:20:07 PM
I know how to change my default. Get the hell out of Memphis
Fatboyman05
Palm Coast, Florida
February 01, 2011, 08:40:04 PM »
per my resident IT support person
on the wx screen, look for a small icon that is an italic i should let you change the location for WX
as for time, you have to go to system prefrences to date and time to set the time zone
YMMV
Bama Red
February 01, 2011, 08:59:15 PM »
FBM05 - thank you kindly!! There is also an italic
i
on the clock for adjusting it. Just far fewer options there. Thanks again!
Last Edit: February 01, 2011, 09:02:01 PM by Bama Red
VRCC Member #32561
Titan
BikeLess
Lexington, SC
February 02, 2011, 06:29:32 AM »
Also, if you haven't noticed it, when you have Dashboard open look in the bottom left corner of the screen and you'll see a circle with a cross in it. Click that and you'll find a bunch of other Widgets. If you see one that you want to use, click it once.
You'll also see a button labeled "Manage Widgets". That will take you to where you can find a few thousand others of all sorts of categories. Most are free. It's pretty much an automatic process to download and install them.
BradValk48237
Oak Park, MI
February 02, 2011, 09:42:33 AM »
Ditto an what Titan Said...... I change em out alot, but use the conversion most along with the calendar
B
