February 01, 2026, 08:51:52 PM *
Author Topic: Seat latch help  (Read 2798 times)
Ferris Leets
Catskill Mountains, N.Y.
« on: February 06, 2011, 12:29:37 PM »
The latch is not working and I need to remove the seat.  Any work a rounds?
I need to get the battery on charge before it gets frozen.
NJF6Cowboy
« Reply #1 on: February 06, 2011, 02:26:21 PM »
same thing happened to me a few years ago. Remove side covers & radiator overflow tank. With a long screw driver from under right side of frame with a good light to see from left side. and alot of patience you should be able to push cable back to unlock.
I replaced my latch system with new after my episode.
Good Luck.
Six Guns
Fort Worth, Texas
« Reply #2 on: February 06, 2011, 03:19:47 PM »
Try pushing down the nose of the seat while you are turning the key to unlock the seat. It's worth a try. Good luck.           cooldude
Ferris Leets
« Reply #3 on: February 07, 2011, 12:55:01 PM »
That was what I had figured out from looking at it.  However I wanted to get someone who had done it to advise on it.  Thanks.  I will take off the water bottle.
Ferris Leets
« Reply #4 on: February 07, 2011, 12:56:03 PM »
Expect a ? about a new battery soon!!!
BigM
« Reply #5 on: February 07, 2011, 02:47:20 PM »
You may want to shim up the latch. I have the corbin seat  (tight fit) and had the same problem til shimmed.
BIG--T
The Twilight Zone
« Reply #6 on: February 07, 2011, 04:38:32 PM »
I see you're in COLD country. Could it have frozen? I've had that problem with cars with door lock iced over and shot a little graphite or WD 40 and it worked. Just a thought.
Ferris Leets
« Reply #7 on: February 08, 2011, 06:23:34 AM »
The latch is if anything too loose.  The cable is not flipping the latch, cold gummy whatever.  Tried spraying it, no go.  After I get it a part I will see what can be done to prevent.
« Reply #8 on: February 08, 2011, 08:22:33 AM »
When you reinstall the front cover, make sure you put the tipover switch right side up!  Do not ask me how I know this.  uglystupid2 hoser
valkmc
Idaho??
Ocala/Daytona Fl
« Reply #9 on: February 08, 2011, 08:46:12 AM »
The cable streches, mine started screwing up and I did not fix it. The next thing I know I was pulled over by a freindly officer and could not get my registration and Ins. Card out. I keep them in a plastic bag next to the tool kit. He let me go but kept me on the side of the road for about 30 minutes. I replaced the cable and it was fine for another 5 years, once it screwed up again I made my own system and threw away the cable. I put a long electrical tie through the latch, locked it into a circle and it comes out on top of the front cover where the seat key goes. You can't see it but now I reach down and give her a gentle tug and she pops up easily. It has been that way for 5-6 years no problem.
2013 Black and Red F6B (Gone)
2016 1800 Gold Wing (Gone)
1997 Valkyrie Tourer
2018 Gold Wing Non Tour
Ferris Leets
« Reply #10 on: February 09, 2011, 05:32:46 AM »
     Thanks for the info.  Got the seat off with little problem.  Got the battery out -more of a problem, PO had added several wires.  It is going to be a PIA to reinstall.  I could not get the front plate off, seems to be attached at the bottom somehow?
      Hoser,  The idea of having to use the key annoys me anyway.  I will be doing something to eliminate that and avoid the cable strech problem as well.
     Since it worked fine before I think that it was my fault for putting too much pressure on the cable.  It was REALLY cold and the key would not turn all of the way until I forced it.  I had started 2 weeks ago to move it into the shop and at first the throttle cable was frozen.  Took about 5 minutes at idle to free up.  I also think the start and idle is what caused the battery to get so low on charge.
Thanks again.
