February 01, 2026, 10:28:46 PM *
Author Topic: Cobra Lamp issue. UPDATE  (Read 2508 times)
f6rider
« on: February 15, 2011, 07:09:37 PM »
I am in the process of making my own set of Rivco Spot brackets.
I am at the point I need to pick out a lamp assmbly.
I purchased some 4.5 bulbs, LAPD surplus landing lamps.
And I bought a set of Cobra shells off HDL. My problem is I dont know how the bulbs are held in.
They fit perfect in the outter ring but there is nothing to hold them there. There is a slot in the outter ring that corresponds with the tab in the bulb. I thinkin there is a retainer ring or something I am missing. I have never had a set of lights like this before.
The shells consistent of the shell, and the outter ring and some wires. Thats it.
Thanks for your help
John Wodarski
« Last Edit: February 23, 2011, 09:36:37 PM by f6rider » Logged
« Reply #1 on: February 15, 2011, 07:29:50 PM »
forget them sealed beams....H-3 bulbs are much better and look fantastic....these are cobra made and have the same attachment base as the ones you have but actually light the road.
They can be orderd from drag specialty
http://www.denniskirk.com/jsp/product_catalog/Product.jsp?skuId=213722&utm_source=shopzilla&utm_medium=cse
« Last Edit: February 15, 2011, 07:41:40 PM by Chrisj CMA » Logged
« Reply #2 on: February 16, 2011, 05:52:50 AM »
The sealed beam lamp is held inside the trim ring with a Cobra supplied retainer.
Thanks Chris!  Now i want to spend more money on my Valk  uglystupid2
Sure Mase........thats a good price too......I paid more than that
f6rider
« Reply #3 on: February 16, 2011, 01:16:42 PM »
Ok I am missing some stuff...now were do I find it. Cobra was no help, they dont supply it.
Any ideas I would appreciate it
« Reply #4 on: February 16, 2011, 01:52:43 PM »
Just clic the link I put on my reply..............that light was made for Harleys so if you search for cobra spots for harley you can find it.........
« Reply #5 on: February 16, 2011, 09:19:48 PM »
$45 + shipping and then you're stuck with H3 bulbs - don't get to use your A/C landing lights you already have - MUCH brighter than H3's for the same watts.  Better focus on the reflectors.
You're better off with the shells from JCWhitney which do fit the A/C lights, and cost only $26.99.  Link at whitney is http://www.jcwhitney.com/custom-fit-spotlight-bars-and-spotlights/p2003447.jcwx?filterid=j3
f6rider
« Reply #6 on: February 16, 2011, 09:32:54 PM »
well the JC Whitneys are plan B. Since I have the cobras  I am going to pursue the clips that hold the bulb in place.
I also have a email into HDL to see if they can help. Cobra recommended I buy an assembly. The Cobras were on clearance so I think I am stuck with them. HDL should have been more specific and stated the need additional hardware to retain the bulbs, Cobra said that when they sell them they sell them as replacements and you should use the hardware off your damaged ones..
Walküre
Nothing beats a 6-pack!
Oxford, Indiana
« Reply #7 on: February 17, 2011, 02:21:03 AM »
F6 - I replaced them on my Cobra's with a different style. You are welcome to the pieces you need off mine - in fact, you can have the lights all together. the inside is rusted, but the outside isn't too bad. If I recall, the lamps aren't there, but the wires that hold them in, are. I'll check tomorrow when I get home.
Could ship in a flat-rate box, for $10.95 if you wanted both lights, or probably just a few bucks, in a padded envelope, if you just want the wires that hold the lamps in...
PM me, if you want, and we'll get them to you.
These are what I replaced them with...
2000 Valkyrie Standard
1999 Valkyrie Interstate
2000 HD Dyna Wide Glide FXDWG
Roger Phillips
Oxford, IN
VRCC #31978
Yeah, what she said...
Garland
#618
Hendersonville NC
« Reply #8 on: February 17, 2011, 04:40:58 AM »
I also replaced my original Cobra lamps, but I still have the old shells as well as extra landing lights if you need them.
« Reply #9 on: February 17, 2011, 07:49:12 AM »
What in the world is wrong with H3 bulbs......they are (both together) as bright as my Xtravision Sylvania healdight, effectively doubling the light on the road.  I bought replacements to have just in case at J&P cycles last time I was in Daytona.  The bulbs were like 4 something each.  Havent needed to replace one yet, and its been well over a year now, and mine are on all the time and I ride just about every day.
No complaints here
f6rider
« Reply #10 on: February 17, 2011, 10:06:48 AM »
these 4.5 inch bulbs I have are nos aircraft landing lights.
f6rider
« Reply #11 on: February 23, 2011, 09:48:19 PM »
 A member here sent me and old set of Cobras for use for the clips to hold the sealed beams in.
He had mentioned that he had some emails stating that there were some more folks out there with the same dilemma.
After I looked at the clips I thought I could bend up a set myself.  I had a mangled old coat hanger and a pair of pliers and the clip Roger sent me for a guide. I spent about a minute on it and it looks ugly, but it holds the light in very securely. I think if you are missing the clip you could use the photo for a guide and a coat hanger and you would be in business in short order.
I have sample photos of the clip and my poor but effective attemp if anyone is interested.
Also, I have the remaining Cobra shells , bulbs and rings if anyone would want them.
Thanks Roger. I hope I can return the favor one day.
John Wodarski
Redline +
Northwest Washington
« Reply #12 on: February 24, 2011, 10:11:32 AM »
Yes, I have been looking for them as well. Got some coming from South Florida...thanks Garland!  cooldude
Redline  Cool
tivoklr
« Reply #13 on: February 24, 2011, 07:36:41 PM »
There's nothing wrong with H3's, but come on man, aircraft lights, that's my kind of lighting!
