November 22, 2025, 12:08:18 PM *
Author Topic: Why am I getting so much moisture coming out of my tail pipes?  (Read 2124 times)
HotRod
Henderson, NV
« on: March 02, 2011, 01:30:11 PM »
 Never noticed it before,but latley seems like a lot. Not losing any coolant.
GOOSE
D.S. #: 1643
Southwest Virginia
« Reply #1 on: March 02, 2011, 01:53:20 PM »
it's normal....don't worry about it.
« Reply #2 on: March 02, 2011, 02:23:47 PM »
Check the weather.  Low temperature + high relative humidity = visible exhaust.
Low temperature = colder surface on inside of exhaust = more condensation = drip drip.
Perfect combustion yields CO2 & water.
N8171S
Marlboro, Mass
« Reply #3 on: March 02, 2011, 02:51:11 PM »
Might also be linked to ethanol in the gas which absorbs water.
Bobbo
Saint Charles, MO
« Reply #4 on: March 02, 2011, 02:59:12 PM »
As mentioned, water is a byproduct of burning gasoline.  If you are running rich, the exhaust tends to condense more water, since the rich mixture is cooler.  You might look into that if it continues.
