November 22, 2025, 12:09:53 PM *
Author Topic: final driven flange  (Read 1413 times)
matt
Derry New Hampshire
« on: March 02, 2011, 05:17:58 PM »
Hello I put in garys dampers now I am trying to put in flange(new also) how hard should it be. I am trying a rubber mallet and last half inch does not want to go any help would be great Thanks Matt
Tropic traveler
Silver Springs, Florida
« Reply #1 on: March 02, 2011, 05:57:35 PM »
Somethin' aint right there!
Mine slid right in. Old O-rings not removed? Somethings not lined up.
'13 F6B red for Kim
John U.
Southern Delaware
« Reply #2 on: March 02, 2011, 08:40:59 PM »
I would contact Gary about that. As I recall he has invited at least one other customer with such trouble to contact him.
« Reply #3 on: March 02, 2011, 10:31:18 PM »
I believe I had problems slidding the flange back into the rim when it had fallen out.
How about alignment? Loosen the plate that holds the dampers in, put the flange in and see if it will now go the whole way. Then tighten the plate back up.
matt
Derry New Hampshire
« Reply #4 on: March 03, 2011, 03:28:04 AM »
Thank You for the help I got it together. It is deffinatly a tight fit,there wont be any free play there  Matt
