February 02, 2026, 12:07:35 AM *
Author Topic: Stock carb jets/needles?  (Read 2380 times)
Doc809
« on: March 07, 2011, 05:48:39 AM »
Getting really crappy mileage after rejetting the carbs when I added Cobra 6x6s.  Think I'll go back to the stock jets/needles but I don't know what to buy.  Can anybody give me some info on the size jets, etc. I need to buy?  Does HDL carry the set?  03 std. TIA
How much fun can I have before I have to go to hell?
« Reply #1 on: March 07, 2011, 07:00:53 AM »
stock
100 mj
35 pilots
are sure the mains were changed? usually cobras are nothing more than a needle change. u can raise the clip which lowers the needle. mpg should improve.
Doc809
« Reply #2 on: March 07, 2011, 07:52:30 AM »
Thanks for the info.  Yeah, I bought the entire Cobra rejetting kit and had the stealership redo the carbs.  Maybe that was my big mistake.
« Reply #3 on: March 07, 2011, 08:37:44 AM »
the kit is only needles, no jets in the kit. change the clip position and the mpg will improve, their instructions have them too rich. idle mixture screws should be about 2 to 2 1/2 turns out.
needles leanest to richest,  oem, factory-pro, cobra and dyna are the same.
changing needles is easy, check shop talk.
see the pdf instructions.
http://www.cobrausa.com/fuel_detail.php?make_id=2&model_id=5&model=Valkyrie Tourer&product_type=Motorcycle Fuel Management&product=Carburetor Jet Kit&product_id=66
GOOSE
D.S. #: 1643
Southwest Virginia
« Reply #4 on: March 07, 2011, 10:10:36 AM »
doc809.......i run cobra 6 x 6 pipes on my tourer, with this set-up:  (this works for me.)  main jets:  105/ slow jets:  38/ fuel air screws:  backed out from stop:  1 1/2 turns/stock needles in carbs.  fuel milkeage= 39-42 mpg. i also have is springs in the carbs/i run an is ecm, and have a 6-degree trigger wheell installed.
Doc809
« Reply #5 on: March 07, 2011, 12:05:47 PM »
Thanks for all your help. L
Slammer
Lafayette,La.
« Reply #6 on: March 07, 2011, 06:03:58 PM »
when you install any aftermarket pipes. if you want you can install Interstate springs but leave everything else stock. set your pilots 2 1/4 turns out and go ride.
Slammer
« Reply #7 on: March 08, 2011, 08:53:09 AM »
More people should heed your admonition.
But then, they are non-believers and have to "see for themselves".
Mostly resulting in a more poorly running bike and lots of attending performance problems.
