Westsider
« on: March 10, 2011, 01:10:11 PM » |
thought i would ask anyway...i want to take off my trunk for a while and see how i like it but ill need a light assembly for the fender....maybee trade for ?? will have to lok around and see what i have sitting around..thanks for any info..i see hdl sells it still but not wanting brand new as if i miss the trunk to much....  paul. any other models fit?
« Last Edit: March 10, 2011, 01:36:44 PM by Paul »
we'll be there when we get there - Valkless,, on lookout....
Houdini
VRCC #28458 - VRCCDS#144
Allen, TX
« Reply #1 on: March 10, 2011, 02:17:52 PM » |
any other models fit? I know the Sabre is the same as the Valk.
Westsider
« Reply #2 on: March 10, 2011, 02:40:09 PM » |
Houdini,,do you have the designation for the sabre,,,?thanks in advance.
Red Diamond
« Reply #3 on: March 10, 2011, 02:51:06 PM » |
You can probably get on from PinWall for a reasonable price.
Westsider
« Reply #4 on: March 10, 2011, 03:09:04 PM » |
Thx red d...checked them fleabay all the cycle salvage yards i can handle on goggle.......this valkyrie stuff is getting rarer-? by the day i guess.......
« Reply #5 on: March 10, 2011, 03:25:00 PM » |
Just so you know, I think three other Hondas use the same taillight lens, but the mount parts, while close are not correct, and to work need subtle modification (I don't have details). I ordered new parts and am very happy to have the stock std taillight under my trunk (and also on my supervalk) (I hear there can be a clearance issue if the IS trunk has the OE CB mounted underneath the trunk). Parts list: (this is a couple years old so the prices may have changed a bit) Honda standard/tourer taillight 33701-MZO-67117 RUBBER boot 80122-MZ0-000 001 $5.67 01 COLLAR 17216-HA7-670 002 $3.40 21 RUBBER washer 80219-KCZ-000 002 $2.50 23 BOLT, FLANGE (5X25) 90112-GG2-900 002 $2.50 Maybe the wiring harnesses for the std/tourer 33701-MZ0-671 tail light assembly $110.65 80122-MZ0-000 rubber $5.67 32102-MZ0-000 wiring sub-assembly $5.52 32103-MZ0-000 wiring sub-assembly $8.86 I used the wiring harness sub-assemblies from a Standard and they tied right in to the Interstate system (except for one wire) without cutting anything. For the one wire, I just connected it and taped it to the standing part of the I/S wiring harness because I did not want to alter the original I/S harness. I could have made a better connection if I didn't mind cutting the original harness. Curtis'
« Last Edit: March 10, 2011, 03:28:22 PM by Jess from VA »
john
« Reply #6 on: March 10, 2011, 03:51:52 PM » |
 EBAY ....
vrcc # 19002
Garfield
97 Standard
Phoenix, AZ
« Reply #7 on: March 10, 2011, 04:52:05 PM » |
Valkyrie Bling and More has a tail light setup for sale. Their also one of our sponsers that keep the lights on for us
mario
« Reply #8 on: March 10, 2011, 05:11:50 PM » |
thought i would ask anyway...i want to take off my trunk for a while and see how i like it but ill need a light assembly for the fender....maybee trade for ?? will have to lok around and see what i have sitting around..thanks for any info..i see hdl sells it still but not wanting brand new as if i miss the trunk to much....  paul. any other models fit? check ebay for sabre tailight. i'll check with a buddy sabre rider i know who did a mod on his sabre and see if he still has his tailight assembly available.
Mario 01 Valkyrie Standard (sold) 12 Suzuki V-Strom 1000
Westsider
« Reply #9 on: March 10, 2011, 05:30:57 PM » |
Thanks for the info....looks like a good set up Jess...appreciate the time for all the p/n"s
Houdini
Allen, TX
« Reply #10 on: March 10, 2011, 07:20:15 PM » |
Houdini,,do you have the designation for the sabre I had a '03 Sabre fender in my garage that appeared to be identical but it may have had some subtle difference, I did not do a side-by-side comparison. I am very happy to have the stock std taillight under my trunk Jess, got a pic of that setup? I'd like to see it.
« Reply #11 on: March 11, 2011, 07:09:12 AM » |
Not on hand, I'll have to take one and email you. Cannot find a pic on-line.
Mine got mounted during a tire change without removing the lower fender half. Later, I replaced the 1157 bulb with an LED array board.
Disco
Republic of Texas
« Reply #13 on: March 14, 2011, 12:23:52 PM » |
Sorry to be late to this, Paul, but check with Wanderer. He might still have a trike take-off taillight/turn signal assembly, or two. I got one from him last year to replace the piddly kury thing that was on Janet's VT1100T when we got it. It's the same, so you can expand your search to include VT1100T (ACE Tourer). Strike that last brain fart! The license plate bracket / turn signal assemblies are the same, NOT the taillight.
Phred, is that an entire assembly or just the clear lens?
« Last Edit: March 15, 2011, 10:25:33 AM by Disco »
2000 Bumblebee "Tourer", 98 Yellow & Cream Tourer, 97 Rescue blower bike 22 CRF450RL, 19 BMW R1250RT 78 CB550K 71 Suzuki MT50 Trailhopper .jpg) VRCC 27,916 IBA 44,783
LL
« Reply #15 on: March 15, 2011, 05:54:19 AM » |
I may have an extra. My 2001 I/S has the SuperValk conversion, when I got it I noticed when applying the brake, the illuminated running lite went out and no brake lite. So I bought another tail lite assembly and as I was ready to install it I thought "no lite on when brakes applied? DUH.........................." It's a no brainer! If you GROUND a test lite while checking for power and it works, then under normal op's it doesn't.............CHECK YOUR GROUND!!!!
Let me check my bag of goodies when I get home
LL
 VRCC #472
Wanderer
« Reply #16 on: March 15, 2011, 09:33:25 AM » |
PM sent, Paul, thanks to a heads up from David! Feel free to contact me by e-mail if Larry's does not work out for you. ~Jeff
More Valk Pics...had a couple of Valks once upon a time 2004 DRZ400S 2005 GS1200 1978 CB550K 1977 CB550F
PhredValk
« Reply #17 on: March 15, 2011, 11:27:42 AM » |
I re-read the ad, and you're right. It might be just the lens. I'll have to call if I actually get around to buying one... Fred.
Old Geezer Richard
« Reply #18 on: March 18, 2011, 08:12:59 AM » |
Hey Paul , look on the classifieds there are two complete tail lite assemblies for sale last I looked , I'm thinking around $75 .... Thanks the Geezer
If you don't care where you're going, then you ain't lost , Murphy's Law because wherever you are going to , it ain't going nowhere .... San Antonio,Tx.
