May 02, 2026, 06:17:20 PM *
Author Topic: "Novelty Horns"  (Read 5115 times)
Tubadoor
Kaufman, Texas
« on: March 15, 2011, 06:24:56 AM »
Last time I got my GEO Tracker inspected they refused to pass it because it had air horns instead of the stock "beep beep". I had to disconnect the air horns and reconnect the original horn to get it passed. Has anyone had a problem with getting their Valk inspected with air horns? I'm thinking I will take the Valk somewhere else to get it inspected. Inspector said that the the air horns were classified as "novelty horns" and would not pass state statutes. Doesn't seem to matter that the louder horn might save your hide.  tickedoff
Tuba be or not Tuba be? Someone answer the Tubadoor!
« Reply #1 on: March 15, 2011, 06:44:28 AM »
When I had my airhorns (Finally got sick of replacing compressors and switched to a different kind) I never had an issue with getting it to pass inspection...
I'd usually warn 'em that they prolly wanted me to demonstrate the horns working outside their shop instead of inside though because they were so loud...
Houdini
VRCC #28458 - VRCCDS#144
Allen, TX
« Reply #2 on: March 15, 2011, 06:57:29 AM »
What kind did you switch to?  My compressor is getting weak and needs replacement.
« Reply #3 on: March 15, 2011, 07:03:30 AM »
Hey there Houdini....I got rid of my beep beeper and since I had already gone to a pingel petcock, I had a vacancy (blank spot) on the left side where the fuel valve used to be , so I put a Stebil dual air horn.  That small thing is two horns and the compressor (no external tubing)  It was around $40 and easy to mount in to work from the stock horn button using a relay (supplied)  I really like it
« Reply #4 on: March 15, 2011, 07:08:27 AM »
I was replacing the compressor every 2 years or so, got tired of it... Got these:
http://www.directlineparts.com/product.asp?pid=7703&str=1
Mounted one on each side attached to the engine mounts... Just checked, ordered these in November of '07 and still have 'em, so a little more longevity than the air horns had...
Rocketman
Seabrook, Texas
« Reply #5 on: March 15, 2011, 07:14:44 AM »
Haven't had any problems in ~5 inspections.  They just want to hear that it beeps.
I would argue that point with them, or just plain leave and go somewhere else.  Too much interpretation of the vehicle code is being done by the inspector himself.  "Novelty horn" implies some sort of Dukes of Hazzard type thing.
tybme
1999 Valkyrie I/S
Topeka KS
« Reply #6 on: March 15, 2011, 08:43:23 AM »
Not trying to hijack the thread but has anyone ever used the Bad Boy air horn? I saw this for the first time at harbor freight over the weekend.
http://www.harborfreight.com/bad-boy-air-horn-94117.html
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways. totally worn out, shouting, "Holy ****... What a Ride!"
Tubadoor
Kaufman, Texas
« Reply #7 on: March 15, 2011, 08:59:23 AM »
I couldn't agree more!
Tubadoor
Kaufman, Texas
« Reply #8 on: March 15, 2011, 09:06:40 AM »
These will be my replacements as well. Haven't had any problems with the air horns yet - except a stuck relay one night - had to pull off the side of the freeway and yank the wires loose as I was starting to think there was a tornado siren going off!
Daniel Meyer
Moderator
The State of confusion.
« Reply #9 on: March 15, 2011, 09:14:41 AM »
No problem with air horns...there is no "novelty horn" rule.
They CAN reject if the horn is "unusually loud or harsh", but on the other hand it has to be heard clearly for 200 feet.
Usually not worth arguing with an inspector that is out of bounds though...big fish, small pond thing and he'll just keep finding reasons even if you win an argument...go to another place and use them.
Something useful for you Texas folks...
THIS is the criteria your stuff must have to pass inspection:
http://www.txdps.state.tx.us/vi/inspection/item_insp.asp
The inspectors have no latitude.
CUAgain,
Daniel Meyer
Rocketman
Seabrook, Texas
« Reply #10 on: March 15, 2011, 09:33:47 AM »
"have no", and "take no" are two different things.
However, definitely concur on the going elsewhere, except you've already paid him, and you don't have to pay again if you come back within however many days, so going elsewhere costs you another fee.  I did that once with my truck.  Had to change a piddly thing, made him happy, got the sticker, told him he was an idiot, and never went back.
Additionally, it wasn't a fail, but I have only been asked once to actuate each brake separately on the Valkyrie to verify brake light activation via both foot and hand.  I looked at the criteria on that website, and there's no mention of that.  I think he would have failed me if he didn't see the brake light activate both times (when he told me to use the foot brake, and when he told me to use the hand brake).
The code is not written such that it clarifies.  If they were going for "no latitude", they would either say "IS" or "IS NOT" required to activate with hand and foot separately.  If course, if it says "IS", then Bandit wouldn't be able to register his here.
I'm sure there are plenty of cases like that.  I wonder if they would fail me if I had one brake lamp out.  The I/S comes with two, and I'm only required to have one, but I bet there are inspectors out there who would fail me for having one out anyway.
« Last Edit: March 15, 2011, 09:44:03 AM by Rocketman » Logged
Disco
Republic of Texas
« Reply #11 on: March 15, 2011, 09:55:25 AM »
...has anyone ever used the Bad Boy air horn?
The Wolo Bad Boy is very similar (licensed? private-labeled? chinese rip-off?) to the Stebel Compact Nautilus.  Search the Tech Board and you'll find lots of info.  I'm on my second one - the first one got weak and then quit.  I suspect a lethal cocktail of Lime Creek Road Silt ( 2funny  ) + several days / thousands of miles of rain up to InZane X and back.
22 CRF450RL, 19 BMW R1250RT
78 CB550K, 07 Helix
71 MT50 Trailhopper
Bobbo
Saint Charles, MO
« Reply #12 on: March 15, 2011, 10:12:56 AM »
This is only a rumor I've heard  coolsmiley but some shops make the vehicle inspectors find something wrong with a car that is only getting an inspection.  If you have something else done, like an oil change, they will ease up on you.
Ten Bears
Denton, Texas
« Reply #13 on: March 15, 2011, 12:46:21 PM »
I replaced my air horns with elctic horns back at Inzane in Frisco. They are loud and work great.
Ten Bears, Founder of the DFW VRCC Chapter, Past President
Brad
Reno, Nevada
« Reply #14 on: March 15, 2011, 02:41:34 PM »
I failed an inspection in Texas on a 1970 Ford mustang.  Inspector said that the  high beam indicator wasn't bright enough.  I told him that the little red pony can be clearly seen at night.  I just went down the street and had another inspection done and never went back to the first shop.
laserpat
Cedar Park, Texas
« Reply #15 on: March 15, 2011, 03:26:05 PM »
I have the bad boy hidden mounted, I thing it's the same as the steubel You can get an extended warranty from harbor frieght for like $7 with free replacement,  cooldude recommended
john
tyler texas
« Reply #16 on: March 15, 2011, 05:19:01 PM »
big bf  "quad horn " setup is very loud     Shocked
mounds under swingarm    coolsmiley
 undetectable       Undecided
vrcc # 19002
GreenLantern57
Hail to the king baby!
Rock Hill, SC
« Reply #17 on: March 15, 2011, 06:19:01 PM »
All factory bulbs have to be working, 2 bulbs factory, then 2 bulbs working. I had a truck that had side markers that also blinked, one side didn't work, had to fix, but he also showed me the text that proved it.  He wasn't being hard case. They had state in thier shop that week. The week before, they had a visit from a decoy car from the state , but had caught the problems.
Houdini
Allen, TX
« Reply #18 on: March 15, 2011, 07:47:55 PM »
Got these:
Brian, do you think these horns will fit in the Interstate pods?
« Reply #19 on: March 15, 2011, 08:32:13 PM »
I haven't been around Interstate pods enough to even hazard a guess, but I went out and measured one of 'em if that helps, it's 3 1/2 inches at it's wides point, 3 inches at it's narrowest, and 1 1/2 inches deep...
(Rough measurements, I didn't bring my calipers Wink )
Next time we're in the same place with a few tools, hit me up, I should be able to take one off really easily (Just one bolt needs to come out, and then pull the plugs on two wires, but they're the slip on kind) and you're welcome to see if you could make it work...
Rocketman
Seabrook, Texas
« Reply #20 on: March 15, 2011, 08:59:52 PM »
Got these:
The Wolo/Stebels will, and I'd be surprised if those are bigger then the Stebels.
chauffeur
Mansfield, Texas
« Reply #21 on: March 15, 2011, 09:25:35 PM »
I installed one inside the right side POD last year.  It easily fits (including the interposing relay and associated wiring).
Only took a couple of hours.
If ya need photos, let me know.
hotglue #43
« Reply #22 on: March 16, 2011, 08:16:22 PM »
I put one of these on my old Valk..... It was louder than you would expect!!!!! coolsmiley  I'm sure I will put one on the new Valk!!!!!
Serk.... don't give me away....LOL
http://www.ebikestop.com/dimension_bugle_horn_chrome-BE1054.php?cat=1046
« Last Edit: March 16, 2011, 08:19:30 PM by hotglue #43 » Logged
 blue=3 times
 green=at least 4 times
« Reply #23 on: March 16, 2011, 08:18:14 PM »
I still tell stories about that horn on your Valk Mr. Glue... Been really tempted to imitate it from time to time, that was pure genius!
hotglue #43
« Reply #24 on: March 16, 2011, 08:21:45 PM »
LOL... while you were posting that.... I was editing for you to not give me away.....LOL
It's easy to do... and the horn button still works....
And it did pass inspection!!!!!!
« Last Edit: March 16, 2011, 08:36:41 PM by hotglue #43 » Logged
 blue=3 times
franco6
Houston, TX
« Reply #25 on: March 17, 2011, 02:31:21 PM »
with the air horn compessor, when mine gets weak I spray the air intake with wd-40 ,brings it back to life. the rollers get gummed up with outside gunk  cooldude
Enjoy the ride!
lucky_1_chris
Arlington, TX
« Reply #26 on: March 17, 2011, 09:45:44 PM »
A buddy of mine has used this horn on his V2K for about 2 yrs. now. No issues. Use a relay.
1999 Valkyrie Interstate
