February 02, 2026, 01:46:58 AM *
Author Topic: slime pumps or others  (Read 2292 times)
spin
« on: March 21, 2011, 07:42:48 AM »
I'm in the market for a compact tire pump to carry.  I've seen 2 that Slime sells.  One is quite small and cheap.  Can it handle the job of inflating a tire without crapping out?  Anyone have experience with them?  Other sources?  I don't really want to spend a lot of money  (I've seen some upwards of $100!) on something I hope I will never need but then again I don't want to kick myself for not spending a few more bucks if an inexpensive one does not do the job.
Also how about the Slime juice stuff?  Does it really  work?
« Reply #1 on: March 21, 2011, 08:12:30 AM »
It's been reported that the slime corrodes the wheels and if you have to repair a tire (mount/remove) it makes a very nasty job.
The inflaters that use a co2 cartridge are small and nice. Takes a couple or more to get rideable pressures.
X Ring
VRCC #27389, VRCCDS #204
« Reply #2 on: March 21, 2011, 10:01:28 AM »
The compact Slime air pump works pretty well,  I even used mine to air up a flat truck tire.  Instead of using Slime in the tire use Ride On.
Marty
NITRO
Eau Claire, WI
« Reply #3 on: March 21, 2011, 10:33:40 AM »
I bought one last fall from Aerostich. I checked to make sure it works, but have not had to use it yet. It has very good reviews, and if it's anything like the rest of Aerostich's goods, it is top quality.
http://www.aerostich.com/prevent-or-repair/tire-repair/pumps-air-compressors/aerostich-mini-compressor.html
When in doubt, ride.
« Reply #4 on: March 21, 2011, 11:35:11 AM »
I bought multiple air pumps from our local store, Canadian Tire. I waited for a sale, got them for 1/2 off @ $10. Says not to use longer than 10 min, with a 10 min cool down before using again. I have one in my bike, I move to my car during the winter, and one in my wife's and mother's car also.
I found most tires are inflated in the low 30's in 10 min. Has a preasure guage built in.
Tropic traveler
Silver Springs, Florida
« Reply #5 on: March 21, 2011, 08:22:57 PM »
Bought a compact Campbell/Hausfield {sp} compressor from WallyWorld several years ago. Snipped the cig lighter plug off it & added 2 alligator clips for the power wires. Made a "road emergency kit" up with tire plugging stuff & it goes in the saddlebag of one of the Valks we ride on any trips.
I've had to use it twice on my Valk.
Pic is from a roadside repair we did on a fellow's HD on the way back from the Starke BikeFest last summer. It spit the plugs out twice during the ride back to the Harley shop & the little cheapy compressor worked like a champ every time!  cooldude 40 psi in about 3-5 minutes.
'13 F6B red for Kim
Bone
« Reply #6 on: March 22, 2011, 02:26:57 AM »
I bought a Slime Pump and wanted to use it before packing it in the bike. Pumped one of my Jeep tires to 50 lbs. I run a CT.  Packed in the original box it fits in the end of the saddlebag of my Tourer.
« Reply #7 on: March 22, 2011, 08:31:06 AM »
I got a very nice compact pump from Wally World for like $20.    It works great.
I found out that it needs to be run every 6 months or the piston sticks.   It is 4377 to get loose also and then it never worked correctly after that o it became landfill fill in.
I actually got 2, 1 for the Valk and 1 for the Chevy Trike.
At home is 2 big air compressors and if the wife is on the road, we got her a AAA Road service.
« Last Edit: March 22, 2011, 08:32:58 AM by R J » Logged
« Reply #8 on: March 22, 2011, 09:27:09 AM »
I used mine on the whiskey run last year to inflate a valk tier after plugging it.  No problems.  They do say not to run it longer than 10 continuously without giving it a break.
thunderbass53
Colorado Springs, CO
« Reply #9 on: March 22, 2011, 01:41:01 PM »
The larger Slime pump is the same one that Honda sells....I got mine at HDL, but fortunately haven't needed it yet!  Grin
Michael
1997 Valkyrie Standard
X Ring
« Reply #10 on: March 22, 2011, 02:30:10 PM »
This is the one I have.  Includes a zippered case to to keep everything in.
http://www.slime.com/product/111/Power-Sport-Tire-Inflator-%28%2340001%29.html
Marty
Ken Tarver
North Mississippi
« Reply #11 on: March 22, 2011, 04:34:42 PM »
i have the Campbell/Hausfield also from walmart, $10 at the time, have used it a bunch of times.....5 minutes of run time for me and then a little break (burned up a cheapie years ago when it ran for 20 minutes.)
Ken
