February 02, 2026, 01:46:59 AM *
Author Topic: Time for some new shocks....  (Read 1805 times)
Stanley Steamer
Athens, GA
« on: March 25, 2011, 03:15:08 PM »
I ride alone 99% of the time...I've only had to ride folks on the back of the bike a few times.....I do pack the trunk on the I/S full when I go on a long ride, just not the same thing as having a passenger on the back.....
I was wondering if the Progressive 412HD's would work ok instead of the pricier 440's??......and I can't remember if the OEM shocks are 12", 12.5", or 13" stock??....I hate to spend a lot more $$ for something that won't help me.....anything would beat the OEM's I have now with 84,000 miles on them......
I'm thinking that I also need to change out the two timing belts for piece of mind.....
Stanley "Steamer"
"Ride Hard or Stay Home"
valkyriemc
NE Florida
« Reply #1 on: March 25, 2011, 04:03:09 PM »
Have you tried adjusting the original Interstate shocks up? Or if that doesnt pan out look for some low miliage take offs. Those shocks have a good record in my book. Also double check your shock bushings top and bottom if you havent already. G/L
Veteran USN '70-'76
« Reply #2 on: March 25, 2011, 04:11:02 PM »
Yes... check your bushings, if you haven't ever changed them out, I'm sure they're wore slap out,
and it is an easy fix.
I have 13" HD 440's, I like them... not so much before I got the HD springs.
People really like Works Performance shocks, I find myself wishing I had tried them, that's what
you should get  Wink ...
You ride plenty fast, and in the mountains, you need good action, not just a lack of bottoming out.
Here's some old threads about 412s...
http://www.valkyrieforum.com/bbs/index.php/topic,19690.0.html
http://www.valkyrieforum.com/bbs/index.php/topic,8923.0.html
Stanley Steamer
Athens, GA
« Reply #3 on: March 25, 2011, 04:48:56 PM »
I've replaced the shock bushings at least once......I'm not really saying that there is a problem with the OEM's......just that new shocks should ride better than the old ones that are 11 yrs old and have 80,000+ miles on them......
Maybe it's like not knowing how much BETTER a new mattress is compared to the old one after the fact??..... cooldude
Stanley "Steamer"
Tropic traveler
Silver Springs, Florida
« Reply #4 on: March 25, 2011, 05:42:22 PM »
Stanley, my stockers were shot right at the same mileage as yours. Set on 5 and they still were mushy.  Shocked
'13 F6B red for Kim
Stanley Steamer
Athens, GA
« Reply #5 on: March 25, 2011, 06:17:07 PM »
I haven't really noticed a "mushy" ride....I think I'm going to need some new ones just to know if the OLD ones are loose...... Cheesy
I did have Progressives put in the front a few years ago....with a 15W oil.....I liked the stiffer front end after that...it made hard stops much better without the nose dive!.... cooldude
Stanley "Steamer"
GOOSE
D.S. #: 1643
Southwest Virginia
« Reply #6 on: March 25, 2011, 08:27:22 PM »
STOCK SHOCK HEIGHT IS 13 INCHES.  STOCK  SHOCK BUSHINGS ARE WORN OUT AT 11-12 THOUSAND MILES.  BUY YOURSELF A PAIR OF STOCK BUSHINGS FOR THE BOTTOM, AN ORDER YOURSELF A SET OF POLYURATHANE BUSHINGS FOR THE TOP FROM DARREL AT XF6-CUSTOM.COM.  I USE THE BUSHINGS THAT HE MADE, AND PERSONALLY THEY ARE AWSOME. cooldude cooldude
