March 22, 2026, 10:12:30 PM *
Author Topic: Has anyone tried this Cruise Control?  (Read 2140 times)
Flashmac
Brookhaven, MS
« on: March 31, 2011, 03:24:18 PM »
My Audiovox cruise control has stopped working. I think that it has shorted out in the servo motor or the switch. The switch is not waterproof and the smallest amount of water in it would always make it quit working. I have found a Victory Cruise kit on eBay and thinking about trying it.
http://cgi.ebay.com/ebaymotors/09-11-VICTORY-VEGAS-KINGPIN-CRUISE-CONTROL-KIT-2877177-_W0QQcmdZViewItemQQhashZitem3a64837b29QQitemZ250794441513QQptZMotorcyclesQ5fPartsQ5fAccessories
Anyone had any experience with these yet? Chrome switch that should be able to withstand a shower since it is made for a motorcycle. Anybody???
Garland
#618
Hendersonville NC
« Reply #1 on: March 31, 2011, 03:59:42 PM »
I don't think that is a complete system, but rather switches for a system already in place. It is described as a plug and play setup in several places that I googled.
Walküre
Nothing beats a 6-pack!
Oxford, Indiana
« Reply #2 on: March 31, 2011, 04:26:16 PM »
says plug an play cruise control, not plug an play switches. Just shows the switches as pictures. I would guess that at 400 retail, it would be the entire cruise control.
R
2000 Valkyrie Standard
1999 Valkyrie Interstate
2000 HD Dyna Wide Glide FXDWG
Roger Phillips
Oxford, IN
VRCC #31978
Yeah, what she said...
« Reply #3 on: March 31, 2011, 05:24:02 PM »
If I was going to shuck out $400 for that, I'd go find a MC Cruise from Australia and get it instead.
I've got one on MGM that has been there since the winter of 1998 and 242K+ miles with nary a problem.   It holds the setting you put it on + or - 3 MPH up or down hill.   I love mine.
http://www.spoiledbiker.com/mccruise.html
« Last Edit: March 31, 2011, 05:28:26 PM by R J » Logged
Walküre
Oxford, Indiana
« Reply #4 on: March 31, 2011, 05:39:50 PM »
Uhm...the mccruise is $960...a bit more than 400...
http://www.spoiledbiker.com/valkyrie.html
And, the 400 is retail, the ebay price is about 1/2 that, so far...
« Last Edit: March 31, 2011, 05:41:44 PM by Walküre » Logged
Roger Phillips
Oxford, IN
VRCC #31978
Flashmac
Brookhaven, MS
« Reply #5 on: March 31, 2011, 06:18:21 PM »
I wish that I could find the switch that the MC Cruise uses. I really believe the switch is where my problem is. Can't afford $959 for that one.
I helped a buddy of mine install the new electronic Audiovox on his I/S last fall. It works great. Just looking for something that is more weatherproof. Really like the looks of the Victory switch. Wondering if anyone has tried installing one.
Walküre
Oxford, Indiana
« Reply #6 on: March 31, 2011, 06:57:27 PM »
I'm not in a place to give too much advice, but will some time tomorrow. Can you give all the symptoms? Switch should be really easy!
R
Roger Phillips
Oxford, IN
VRCC #31978
« Reply #7 on: March 31, 2011, 08:21:16 PM »
More than likely it's your handlebar mounted switch, got moisture in it. Didn't need to happen though, when I mounted mine I separated the two parts that make up the switch box and sealed it with some clear RTV. Snapped it back together and let it dry. Been on there for nearly seven years, in plenty of rain, still works like a champ. The other thing you need to consider if you don't have an I/S....remove the connector that's halfway between the switch and the servo. If you have an I/S that connector will be in the fairing, if not....then it's subject to the elements. Solder the wires together and make sure they're insulated from the elements. Then install a connector adjacent to the servo. Now you will have a waterproof system.
X Ring
VRCC #27389, VRCCDS #204
« Reply #8 on: March 31, 2011, 11:10:30 PM »
Flashmac, I've got an unused Audiovox switch if you want it.  Click on my avatar and shoot me a email or pm.
Marty
Flashmac
Brookhaven, MS
« Reply #9 on: April 01, 2011, 07:46:56 AM »
....when I mounted mine I separated the two parts that make up the switch box and sealed it with some clear RTV. Snapped it back together and let it dry. ....... The other thing you need to consider if you don't have an I/S....remove the connector that's halfway between the switch and the servo. If you have an I/S that connector will be in the fairing, if not....then it's subject to the elements. Solder the wires together and make sure they're insulated from the elements.
I did both of these things but still had problems with moisture. I have power to the switch and the servo but it won't work. The backlight on the switch still lights up but when I punch the ON switch nothing happens. I have checked to make sure that I am getting power from the switch to the servo. But as soon as I let off of the ON button, the power stops. So. I don't know where my problem is.
I haven't worked on it since the Nov. but it is time to get serious about fixing it now. Can't go without my cruise.
Momz
ABATE, AMA, & MRF rep.
« Reply #10 on: April 01, 2011, 09:30:13 AM »
I like to keep this simple and easy (KISS).
A lot of riders are using the Vista Cruise throttle lock. I have one on my I/S and it sort of works, but it covers the Kill Switch.
On my Rat Rod, I have the "rooster & Lock" from "Madcorider". It is a piece of M/C jewelry, but only if you see it though. It blends in so well, most don't even see it.
ALWAYS QUESTION AUTHORITY!
OverdueBill
Elkmont, Alabama
« Reply #11 on: April 01, 2011, 09:37:26 AM »
+1 on the Madco.  Simple, neat. cooldude
ILcruiser
Crystal Lake, IL
« Reply #12 on: April 01, 2011, 10:13:29 AM »
That's a great deal for a full Vic cruise control unit.  I checked around on a couple of Polaris oem parts sites, and the switch unit alone goes for about $135.  Sure would look nice on a Valk if it can be made to fit.
1999 Valkyrie Standard
