Gunslinger
Brian Huntzinger, EMT-P
Wamego, KS
« on: April 01, 2011, 06:28:54 PM » |
Well looks like GOTF is a bust for us. Roadkills wife's bike has some serious issues and we'll be loading it on a truck for the return trip.
VRCC# 26468 VRCCDS# 0228  "Some learn by listening, Others learn by watching... The rest of us have to pee on the electric fence ourselves"
shank
« Reply #1 on: April 01, 2011, 06:40:40 PM » |
Sorry to here that. Well crap Happens... Back up and Punt it will work out.
Gunslinger
Wamego, KS
« Reply #2 on: April 01, 2011, 06:42:45 PM » |
Yep, sucks (and more choice words I won't post here) 200 miles short.
Thunderbolt
« Reply #3 on: April 01, 2011, 06:43:40 PM » |
Just glad there was no accident. Hope the problem is not serious.
Gunslinger
Wamego, KS
« Reply #4 on: April 01, 2011, 07:36:47 PM » |
Got Dale& Lori set, I'm on my way solo. Short 2 bikes and 2 friends.
alph
« Reply #5 on: April 01, 2011, 08:16:54 PM » |
what happened?? what broke???
Promote world peace, ban all religion. Ride Safe, Ride Often!!
Gunslinger
Wamego, KS
« Reply #6 on: April 01, 2011, 11:18:50 PM » |
Hate to guess at this point, V-twin went "pop" and died. No compression. Have some guesses, but none are good
« Reply #7 on: April 02, 2011, 07:09:45 AM » |
Well it's early enough in the season that maybe you won't miss to much of it.  Just hope it ain't to spendy.  Nobody hurt though thats the main thing.  RIDE SAFE.
« Reply #8 on: April 02, 2011, 07:51:07 AM » |
Sounds like she might have burned a hole in a piston. If that be the case, put forged buckets & chrome rings back in it. It will take like 3,000 to 5,000 miles to set those rings, so don't worry about thae blue smoke out the pipes in that time period. It will be a stronger engine.
My son's Chopper engine from S&S has forged buckets and chrome rings. It is either a 113 or a 133 ", and no other mod's. It gives the Valk all he wants in a drag or a 3rd gear roll on.
RoadKill
« Reply #9 on: April 02, 2011, 11:22:13 PM » |
Made it home with the Wife's junk in a U-haul and My sweet Valk parked in with it for moral support . My guess is cam timing/valve train issue. Will know more in the LATE A.M. or afternoon. Did not make the destination,BUT the journey was still a great one....and that is what it is all about!  More details to come L8R . G-Nite
Gunslinger
Wamego, KS
« Reply #10 on: April 02, 2011, 11:24:10 PM » |
Glad to hear you made it with no more issues. Sorry you missed out. Next time!
RoadKill
« Reply #11 on: April 02, 2011, 11:27:51 PM » |
Next time there will be 1 more HONDA in the group for SURE !
Gunslinger
Wamego, KS
« Reply #12 on: April 02, 2011, 11:29:39 PM » |
I offered Kerri's Valk for the trip, I don't wanna hear it!
hotglue #43
« Reply #14 on: April 04, 2011, 02:03:35 AM » |
Gunslinger told me what had happened... BUMMER.....Looks like ya found a fix!!!
 blue=3 times green=at least 4 times When they are all 'green'.. I'll stop counting.
« Reply #15 on: April 04, 2011, 05:50:00 AM » |
Come on fill the rest of us in on the problem and the fix Bro. Tanx.
Gunslinger
Wamego, KS
« Reply #16 on: April 04, 2011, 09:24:20 AM » |
The Problem was the Screaming Eagle that has left her on the side of the road more than once, The fix is the Honda Magna in the garage now.  She is going to hunt me down and hurt me before this is all done.
Rocketman
« Reply #17 on: April 04, 2011, 12:56:37 PM » |
I've heard of that mod. Good to hear that it was just a simple remove and replace job.
RoadKill
« Reply #18 on: April 04, 2011, 02:16:32 PM » |
We were traveling 70-75 mph just past Jacksonville TX. I was riding sweep and saw a 1 foot flame out of 1 pipe when it backfired,Lori turned and motioned that it was dead and we fought traffic a bit to get her to the right shoulder. First check was for spark and we had none but the sound of that 10:1 compression motor spinning over that fast made my stomach churn. I shook it off and went to finding spark  I found a pinched wire behind the ignition module that had found ground,firing the rear cylinder out of time (BACKFIRE) and setting a fault in the Dyna IGN module. Electrical tape and reset static timing and we had spark again! My hopes raised but only slightly because she still spun over too fast for such an impressive (V-Twin) air pump.  Pulled plugs and using my finger checked for compression....It tried to suck my arm into the cylinder but ZERO pressure blowing back on squeeze stroke  :'( ??? At that point I pleaded with Brian (Gunslinger) to be on his way to GOTF and told Lori (ASKED) to call AAA for a wrecker. My denial was over. With both cylinders down on squeeze and a good intake pull I suspected bent valves and a cam timing issue to be at fault (because it affected both cylinders ) Sure enough after 700+ miles in a U-haul I found the ugly truth   The massive misfire had shocked the crankshaft hard enough that the weight of the valvetrain in motion at high RPM sheared the key on the cam gear and probably bent all the valves. I wont know for sure on the valves until the heads are off but a quick check on craigslist (and 2800 $) bought me plenty of time to procrastinate the teardown
« Reply #19 on: April 04, 2011, 06:42:35 PM » |
Sorry to hear of your troubles.... wish you could have made it to the Gatherin'... Hay  Jimmyt
hotglue #43
« Reply #20 on: April 04, 2011, 09:11:16 PM » |
Roadkill.... wish Y'all could have made it down!!!!!! it's a bummer... but don't let it get ya down too much. Hey... same thing happened to my 97 valk... bent and ex valve... pulled the head... replaced the valve and guide.. had it back on the road for many more trips!!!! A valve timing slip on an interference engine will mess up some valves.... We sure missed seein' ya! Hopefully we will hook up on a trip this summer!!!! hg
motomama
« Reply #21 on: April 05, 2011, 01:53:11 PM » |
The Magna is an awesome bike! I rode one for several years!
Motomama
