February 02, 2026, 03:14:39 AM *
Author Topic: front end noise only when under load?  (Read 1621 times)
upjeeper
« on: April 03, 2011, 11:09:45 AM »
took the bike our for the first time yesterday. getting some noise in the front end when accelerating or going up a hill, but when maintaining a steady speed no noise
i'm thinking either the bearings or brakes? any ideas?
« Reply #1 on: April 03, 2011, 11:18:56 AM »
Might be a vacuum leak from your earlier work!
Bearing would more or less be a constant thing and brakes could be affected by pulling the brake lever!
Uphill and acceleration, basically the same, except in degree of throttle.
De-smogged or not?
Check you vacuum lines!
upjeeper
« Reply #2 on: April 03, 2011, 11:24:31 AM »
no desmogging, I've thought about doing that, but likely will leave well enough alone. All stock.
haven't really played with any vacuum lines
Madmike
Campbell River BC, Canada
« Reply #3 on: April 03, 2011, 05:35:27 PM »
...  any chance it is something in the exhaust???  Undecided
upjeeper
« Reply #4 on: April 03, 2011, 06:52:37 PM »
could be. I did have one bolt at the header strip out. I need to get it in (had a thread going about doing it myself) to have a shop do the helicoil. maybe an exhaust leak at the manifold could do it?
