January 28, 2026, 01:37:38 PM *
Author Topic: Super Valk Question...  (Read 4246 times)
Big Rig
Woolwich NJ
« on: April 12, 2009, 07:35:20 PM »
This is for all the guys that modified their I/S' into super valks. I am still running my SV with the I/S antenna...I have seen several short antenna out there...I was hoping some one could tell me what they are using and where the got it...
 Smiley
« Reply #1 on: April 12, 2009, 11:44:33 PM »
I'm not running an I/State and or an antenna, but I have seen these short ones in a lot of the Truck stops in my travels..........
A good radio repair shop should also have them.  I know the one I patronize has em......
Andy
« Reply #2 on: April 13, 2009, 03:13:23 AM »
If these guys can't help you nobody can.
http://www.walcottcb.com/index.php
« Reply #3 on: April 13, 2009, 03:19:07 AM »
This is for all the guys that modified their I/S' into super valks. I am still running my SV with the I/S antenna...I have seen several short antenna out there...I was hoping some one could tell me what they are using and where the got it... Smiley
My SV came with a shorter, bag-rail-mounted (clamp) antenna, which I believe is a 'fire stick' model.  The prior owner also had a CB (which I didn't want, and he removed), and the antenna (and the requisite 18' of  cable) is for CB and radio.  I am thinking this antenna is better for CB than radio because it does not work as well for the radio as my OE whip antenna on my other IS.  If you are not running a CB, this may not be a good choice, I just don't know
http://www.firestik.com/CatalogFrame.htm
NiteRiderF6
Doug n Stacy
Mississippi
« Reply #4 on: April 13, 2009, 02:29:35 PM »
I have a short (2') CB antenna from J&M, it does okay...... and it hides away well. I think Big Mike at Valkyrie Bling also sells a 2 in 1 antenna that does a pretty good job. Good Luck
firedude-94
« Reply #5 on: April 14, 2009, 07:38:04 PM »
i purchased a replacement antenna at the local auto parts store. then placed it inside the fairing, it basically spans from one end to the other. i still get great reception without having to deal with an external antenna
Crazyhorse
Hattiesburg, MS
« Reply #6 on: April 16, 2009, 03:16:52 PM »
I purchace mind at a auto store and used a piece of aluminum angle to mount it to the saddlebag rails. Sticks out right by the right rear turn signal.
Mac
