February 02, 2026, 04:47:40 AM *
Author Topic: Something else that can be used as shock bushings  (Read 3220 times)
Warlock
Magnolia, Ms
« on: April 04, 2011, 07:45:04 PM »
I have over 10,000 miles on a set and no wear. They do cost a lot Grin
http://www.mcmaster.com/?orderview=new#6389k344/=bqjmvi
David
wizard -vrccds#125
Hitchcock Tx.
« Reply #1 on: April 04, 2011, 08:19:15 PM »
Looks very interesting after our talk at GOTF. I think I will be orders 20 or 30 of them  cooldude
OverdueBill
Elkmont, Alabama
« Reply #2 on: April 05, 2011, 08:31:39 AM »
I have them on my Valk and VTX.  Work fine and didn't have to save up to buy them. cooldude
lucky_1_chris
Arlington, TX
« Reply #3 on: April 05, 2011, 01:50:21 PM »
These will work on all 4 mounts?
1999 Valkyrie Interstate
Bullgoose
Bastrop, Tx
« Reply #4 on: April 05, 2011, 02:22:07 PM »
Just to make sure, these are for the stock shocks only, yes? Won't work of progressives.
If it's worth doing, it's worth over-doing!
OverdueBill
Elkmont, Alabama
« Reply #5 on: April 05, 2011, 04:27:48 PM »
On a Valk, top 2 mounts.  Stock only I think.
« Reply #6 on: April 05, 2011, 07:53:39 PM »
So these are nylon sleeves, not a bushing at all, ridged.
Did you notice any difference in your ride comfort then?
Did you need to modify to fit, cut shorter?
Garry the bearing guy sells better quality bushings for the Valk/VTX, neoprene I think, so you still get cushioning from them, rather than the ridged nylon one. I'm also sure Garry said that the top/bottom bushings are the same.
I think it is that there is more presure on the tops than the bottom, and they fail 2-to-1 more often.
« Last Edit: April 06, 2011, 10:16:42 AM by gordonv » Logged
OverdueBill
Elkmont, Alabama
« Reply #7 on: April 05, 2011, 09:57:29 PM »
No mods needed.  Just put them on the shocks and bolt them on.  3 years on the VTX and 2 on the Valk.  It's all good.  I probably would have gotten the VTX F model bushings if I had known about them back then.  Got the idea from VTXOA board when I found my X had gone bad in 4000 miles.  They were bad when I got my IS.
N0tac0p
« Reply #8 on: April 06, 2011, 03:30:52 AM »
as all the bshings on my 01 i/s are teh same top and bottom, why did someone you say they only fit the top?  why not all four spots?
OverdueBill
Elkmont, Alabama
« Reply #9 on: April 06, 2011, 09:33:36 AM »
The right bottom one had a metal bushing in it and was ok.  The left was ok.  I left them alone and just changed the bad ones.  Look like they will fit the left bottom easily but I'm not sure about the bottom right side ID where the metal bushing is.  Mine is an 01 IS also.
Farther
Quimper Peninsula, WA
« Reply #10 on: April 06, 2011, 10:56:12 AM »
...neoprene I think....
probably poly urethane.
« Last Edit: April 06, 2011, 10:57:46 AM by Farther » Logged
~Farther
Kaiser
Gainesville, FL
« Reply #11 on: April 06, 2011, 11:11:04 AM »
All 4 are identical.  Just did mine a few days ago.  If they aren't identical, someone please chime in here and save me from what could be a bad situation.
Warlock
Magnolia, Ms
« Reply #12 on: April 06, 2011, 07:06:29 PM »
Only thing I notice is no dancing in the rear end. They are the right length. Only thing you have to do is use a C clamp to install them in the shock.  That's what great about the board. You can buy what you want!
David
