February 02, 2026, 03:14:01 AM *
Author Topic: Rear spline and ring gear problems  (Read 1566 times)
SgtBunny
"Don't be a Lemming!" - MCC
Kingwood, WV
« on: April 04, 2011, 07:48:07 PM »
Ok, so I dropped my read wheel and found a mess.
Here is what my spline looks like and my ring gear looks the same.
Notice a slight wear pattern developing.  I already have good paste to put on it but the question is, can I trust this to get me through this season?
My initial thoughts are yes and I will replace my final this coming winter.  Any thoughts?
« Last Edit: April 04, 2011, 07:52:39 PM by SgtBunny » Logged
VRCC #29625
'98 Tourer
« Reply #1 on: April 04, 2011, 07:50:21 PM »
keep it properly lubed and it will go more than a season........ cooldude
wizard -vrccds#125
Hitchcock Tx.
« Reply #2 on: April 04, 2011, 07:52:42 PM »
I have seen alot worse that were still going with no problems. Clean and grease well and GO RIDE! Just do not let then go that long again with out service !
SgtBunny
Kingwood, WV
« Reply #3 on: April 04, 2011, 07:56:42 PM »
Yeah, I should have checked them when I first bought the bike.
Since the guy before me had taken care of everything else so well, I had no thought that he would have let that go.
You know what they say when you ASS-U-ME!!!
Thanks as always.
BTW, I think it is a good time to pull the shaft and check it too.   Grin
VRCC #29625
'98 Tourer
olddog1946
Moses Lake, Wa
« Reply #4 on: April 04, 2011, 08:27:49 PM »
Mine looked about the same when I pulled the wheel for a new tire..cleaned it all up and it was actually in pretty good shape (luckily)...I did not use the paste but a moly type lube grease....the paste seems to dry out/wash out ..hope I haven't generated my own problems from that..have about 4 k on it now and will pull it apart next month to check the drive shaft and ujoint condition while I'm at it...want to be sure I get to Az and Back with worrying about the driveline.
« Last Edit: April 05, 2011, 07:06:49 AM by olddog1946 » Logged
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
Tundra
2014 Valkyrie 1800
Seminole, Florida
« Reply #5 on: April 05, 2011, 03:00:57 AM »
I actualy think they look good, compared to what I've seen. Clean/grease and ride cooldude
