July 08, 2025, 05:23:30 AM *
Author Topic: Dyna3000 ground switch  (Read 2216 times)
brillo1542
wheaton, il
« on: April 13, 2009, 04:29:18 AM »
I have read about the ground switch used to modify one of the spark advance programs.  I would like to know where to get such a waterproof switch and see how other members have installed it on their Valks.  Thanks.
nortman
« Reply #1 on: April 13, 2009, 06:50:58 AM »
switch from Directline parts (BIG-52605) that mounts on the brake res.  That in turn, operates a relay.  I wanted the switch close at hand, as I am running a modded trigger wheel with 7 degrees of advance.  Unless I am cruising at a steady speed,  I run curve 7 with the wire grounded and 10 degrees of retard (but that equals out to only 3 degrees off of the number 7 curve.  Then when I am on the open road, I cut out the ground and add the 10 degrees back to the curve for gas mileage.  I just got home from work this morning and averaged 34 mpg for my 142 mile round trip commute. It consists of 120 miles of x-way with city and town driving on each end.  I run between 75 and 80, with a shot of 85 or so now and then.  The bike is a 97 standard with 50,000 miles, Goodyear TT 205X60X16 rear @ 36psi, Avon Cobra front @43 psi, cut piggies, K&N filter, IS springs, a National Cycle windshield and light bar, Baker air wings, hand deflectors, home made foot deflectors (all this adds up to a lot of wind resistance), and Leatherlyke bags.  I weigh 250 with coat and helmet.  When the bike ignition was stock running that fast, I would get around 26 to 27 mpg  cooldude
« Last Edit: April 13, 2009, 06:57:55 AM by nortman » Logged
YardBoy
« Reply #2 on: April 13, 2009, 08:22:52 AM »
This switch might do the job.
http://www.monstermarketplace.com/Automotive/Landing2778a588.html
