February 02, 2026, 04:47:40 AM *
Author Topic: De-Smog?  (Read 1667 times)
Dougs2000IS
Wisconsin
« on: April 05, 2011, 05:25:55 PM »
I just De-Smogged my 2000 interstate with 68K. Also new intake o-rings, Most of the the vacuum lines and that is what I have a question about. I purchased just about all the supplies from redeye. I ordered the Pingel petcock vac line. Should of I ordered the Valkyrie Pair Valve Vacuum Line? The Pingel instructions tells me to install the vac line directly from #6 the gas valve. I think I need to keep the pair valve vac line set up, Is that correct? Oh It runs great just the way it is. I took it for a ride in the 45 deg Wisconsin evening. Hope I remembered everything and if not I will give more info. Thank you all in advance. Doug
2013 Victory Vision Arlen Ness
2000 Valk Interstate (sold)
1997 Ford F150
2006 Honda Civic Hybrid
Go Packers
bikerboy1951
Grand Forks, ND
« Reply #1 on: April 05, 2011, 05:34:52 PM »
If you did the desmog, you need to cap (plug)  the number 2 and 5 ports that the pair valves were connected to.  If your Pingel is a vacuum model, you will need to connect it back up to the number 6 port.  If it is a manual valve, that port needs to be plugged also.  And don't forget to plug the nipple on the bottom of the airbox that the control valve was connected to.
Brad
fat6man
Crystal City, Missouri
« Reply #2 on: April 05, 2011, 07:52:23 PM »
For a nice Clean look on the air box I ran a 5/16"-18 Tap into the port and then Installed a bolt with sealant on the threads. Quick and easy!!!
« Reply #3 on: April 06, 2011, 07:02:04 AM »
You need those ports (barbs) accessible for a synchronization.
« Reply #4 on: April 06, 2011, 01:45:48 PM »
Im confused..........you shouldnt need vacuum lines after a desmog, thats the whole point.  If you bought a vacuum Pingel, then, sure youd have to have that line, but why order it?  You can get a couple feet of vacuum line 5/32" ID for a dollar or so at your local parts house
