March 07, 2026, 07:17:03 PM *
Author Topic: GOING TO THE DARK SIDE  (Read 3497 times)
rainman
Steve ( rainman) Eads
Bloomington Indiana
« on: April 14, 2009, 05:06:20 PM »
Hell-o everyone
going to try this new post. for the first time.
I have a ? for you dark siders.  I am going to go to the dark side as soon as I wear out my rear tire and I know I have seen some of you talking about tire size and RPMs I do not want to have to cut anything on the ol gal so some refresh my mind. What size am I looking for
28481
"RAINMAN"
Dag
Country Rep. Norway
« Reply #1 on: April 14, 2009, 05:12:53 PM »
ME TOO    205/55/16
Rear Wheel Removalpowered by Aeva
« Reply #2 on: April 14, 2009, 05:23:25 PM »
I also have a 205/55 Hankook. Not sure about the nut cage removal since I already did mine few years ago when I went to the 200 Metz. If you ride 1 up and 200 lbs, I think you'll be fine. But its alot easier to do when you have the tire off now then it is to find out later you shoulda.
Only handling issues I found was it wanted to set me up on a ruff slanted highway. I was on a outside lane due to riding somewhat side by side. Other then that no turning issues at all. Felt like my 200 Metz.
Momz
ABATE, AMA, & MRF rep.
« Reply #3 on: April 14, 2009, 05:57:22 PM »
Try not to have too much fun!
ALWAYS QUESTION AUTHORITY!
Stick
Sherbrooke Nova Scotia
« Reply #4 on: April 14, 2009, 06:22:21 PM »
This is a good article re rpm
i went with 205/60/16 Goodyear triple tread dont notice any change in rpm
2001 Valkyrie Interstate Burgundy/Black*Sold*
2000 Valkyrie Interstate-Black*Sold*
2000 Valkyrie Supervalk-Blue/Silver*Sold*
Sharkey
GOT CURVES??
VRCCDS0184
« Reply #5 on: April 14, 2009, 06:28:33 PM »
205/60/16 at 34 psi
No change in rpm, but did the nut cage mod just to be sure. It easy to do when changing the tire like Fugie said.
Lots of good info here
http://mcdarksiders.forumotion.com/
JDW365
North Newton, Kansas
« Reply #6 on: April 14, 2009, 06:42:12 PM »
ME TOO    205/55/16
Rear Wheel Removal
Dag thanks for the video that helps me a lot I am getting ready to do my tire here in the next few weeks and now I have an idea what I am getting into. JDW cooldude
stormrider
Kinsey, AL
« Reply #7 on: April 15, 2009, 06:19:04 AM »
Look for a tire that has a soft tread compound, good wet weather handling, good traction, etc. The 205-65-16 is the nearest in circumfrence to a stock size but is extremely limited on choices. I found that the Bridgestone Potenza g109 grid fits the criteria I was looking for. SmokinJoe and several others run the Cooper Zeon 2xs however it only comes in a 55. It has a very soft compound, I think about a 330, but I'm like you, I didn't want to give up the rpms. The potenza comes in a 205-60-16 and has a 460 compound. The Michelin triple tread along with most others of similar size have a much harder compound which to me means less traction thru the twisties. I don't ride the twisties as aggresive as others but there are times a curve slips up on me and I want to know that what is on my rear will do it's job. So far it has performed flawlessly. I've had to test it a time or two. Rides very smooth, not much noise, works great in the rain, no flaws so far.
