February 02, 2026, 08:21:51 AM *
Author Topic: exhaust studs  (Read 1726 times)
RichIAFF
« on: May 01, 2011, 04:51:51 PM »
I got these by accident but installed them and there better then OEM the stud end into engine is the same but the end the nut goes on is 7mm so you have to drill out the hole in the exhaust flang a little but no more snapped bolts  Stud part #90035-MM5-000 Nut Part# 90304-MM5-000
« Reply #1 on: May 01, 2011, 06:35:55 PM »
Where these just a stud from some other Honda, or are they from something (Valk, GW, model years)?
« Reply #2 on: May 02, 2011, 12:10:41 AM »
Well Rich, It's probably a good idea if snapped off studs are a problem plaguing you, but I've installed hundreds of Valkyrie exhausts in my shop over 12 years and have never snapped one.  Maybe just using a torque wrench would be an easier solution.
YoungPUP
Valparaiso, In
« Reply #3 on: May 02, 2011, 02:25:49 AM »
Good job jinxing yourself.... uglystupid2 cooldude
99 STD (Under construction)
9Ball
« Reply #4 on: May 02, 2011, 03:17:13 AM »
those studs are a bit weak on purpose....beefing up the stud size is not necessarily a good thing if you strip out the aluminum head.
+1 on the torque wrench.
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
RichIAFF
« Reply #5 on: May 02, 2011, 03:50:35 AM »
These studs are from another Honda with and alum. Block I'm sure honda saw the problem in a newer model and up graded the studs. you still have to use a tork wrench
