February 02, 2026, 08:40:15 AM *
Author Topic: Air Shocks  (Read 1656 times)
rbert
« on: May 02, 2011, 04:27:09 PM »
I have been running Works shocks for the last couple years, but they are not smooth enough for my wife. I have been thinking of going to air shocks. Any comments about comfort and handling? Any recomendations on the best make of air shocks?
Warlock
Magnolia, Ms
« Reply #1 on: May 02, 2011, 06:36:40 PM »
I just got a set of 416 air shocks from one of the members. Haven't installed them yet. Going to put new oil seals in them before installing. If you sell the work shocks give me a hollow david91854REMOVE@yahoo.com  discard the obvious
David
Colin
My old job
Orba, Spain
« Reply #2 on: May 02, 2011, 09:54:46 PM »
I run the 416's and like them and so does SWMBO which is even more important. Very easy to up and down the pressure if she is on the back or if I am solo. Others on here don't like them though. It is really personal.
Colin
VRCC Espana
My Bumble Bee re-build
Gryphon
Resistance is futile; if less than 1 ohm.
Fulton, MO
« Reply #3 on: May 03, 2011, 06:20:21 AM »
I also have the 416's.  My wife likes the ride much better than when I had the original shocks on the bike.  I believe most of it is because it's easier to adjust them for the load: solo, 2-up, 2-up with stuff.  Some don't like them and will tell you you are better off with the heavy duty conventional shocks.  Personal preference.  I may add an onboard compressor sometime in the future.
aslondon
VRCC #4321
Monticello, Fl
« Reply #4 on: May 03, 2011, 07:24:32 AM »
I had 416s and found them harsh.  I now have the 440's and like them alot.  I've had the Works on my last bike.  if you'd like to swap my 440s for your works, I'd entertain that idea.
Al
vrcc 4321
