February 02, 2026, 08:40:13 AM *
Author Topic: standard seat on a interstate?  (Read 1829 times)
Fajack
« on: May 03, 2011, 12:31:16 PM »
I have an Ultimate King   seat on my standard and am thinking of buying an Interstate.  Will this seat fit my new bike?  Thanks in advance
Jack  99 Standard
Bullgoose
Bastrop, Tx
« Reply #1 on: May 03, 2011, 12:33:45 PM »
I contacted them a few months ago re: this same idea. They said no, it won't work. So I didn't buy the interstate tank. Bummer.
If it's worth doing, it's worth over-doing!
tank_post142
south florida
« Reply #2 on: May 03, 2011, 12:52:40 PM »
you will need the fender bracket that holds the rear of the frt seat as well as the frt of the rear seat also you will need to bolt down the rear of the back seat, in addition: the interstate tank is much steeper at the rear so your seat may press against the rear of the tank. members have protected the paint by affixing a clear plastic to the rear of the tank and have successfully done this swap.
« Last Edit: May 03, 2011, 12:54:13 PM by tank_post142 » Logged
I got a rock Sad
VRCCDS0246
« Reply #3 on: May 03, 2011, 07:38:17 PM »
The fender bracket is there.  The bolt is there on the fender.  You may want to swap it with one of a better appearance.  Ultimate Interstate pillions have the same need.
The nose of the saddle will wrinkle against the Interstate tank.  It won't look good and an Ultimate seat should look good.  That's the only difference in using the Standard saddle.
tank_post142
south florida
« Reply #4 on: May 03, 2011, 08:24:40 PM »
thanks willow. it's been a while since i broke down an interstate
I got a rock Sad
VRCCDS0246
