February 02, 2026, 08:35:18 AM *
Author Topic: Saddlebag Rails  (Read 4034 times)
2qmedic
Simply Awesome!!!
« on: May 04, 2011, 11:41:40 AM »
Greetings All,
First off, I did a search and didn't find anything (maybe I wasn't spelling it correctly or sumthing).
The cost of OEM Saddlebag Rails are ........out of my price range when they do appear.
Any comments of the MC Enterprises Saddlebag Rails below?
Workmanship, chrome, ect...
Are they strong enough? looks like the forward verticle piece would be the mainstay for this.
(realizing the photo is not of a Valkyrie)
Thanks in advance
http://www.motoshop.net/mm5/merchant.mvc?Screen=PROD&Product_Code=PUMC47413&Store_Code=AIM&search=Valkyrie+%2C+saddlebag+rails&filter_cat=&PowerSearch_Begin_Only_=&sort=&range_low=&range_high=&layout=
« Last Edit: May 04, 2011, 11:46:59 AM by 2qmedic » Logged
« Reply #1 on: May 04, 2011, 11:51:16 AM »
I realize the OE rails are prohibitively expensive, but the MC rails look like curtain rods to me.
Still, the bags are also expensive, and the MC rails do offer some protection.
N8171S
Marlboro, Mass
« Reply #2 on: May 04, 2011, 03:44:57 PM »
I have a set that were on my tourer for two months while my originals were out for chrome.  Have the instructions and all, $150 +  shipping.  tommanell@aol.com
PhredValk
Edmonton, Alberta, Canada
« Reply #3 on: May 05, 2011, 12:09:09 AM »
You're not the first one to buy these, I'm thinking of getting a set myself...
http://www.valkyrieforum.com/bbs/index.php/topic,22875.0.html
Fred.
VRCCDS0237
« Reply #4 on: May 05, 2011, 05:56:30 AM »
If you got a hitch or getting one, forget it. I couldnt get mine to fit. Even cut my new set up trying to get it to fit. Now they hang from the rafters in the garage.
Now Painter got his to fit with his hitch and they look good.
« Reply #5 on: May 05, 2011, 07:20:22 AM »
The original Honda bag rails are a very good addition to the Valkyrie.
All you have to do is install them and you will realize how very much they add to the strength and stability of the whole rear end, the bags and everything.
Honda doesn't miss a thing in the design and finish.
2qmedic
Simply Awesome!!!
« Reply #6 on: May 05, 2011, 08:09:17 AM »
Yep, I absoutely agree....just a money thing.....or lack of....
donaldcc
Palm Desert, CA
« Reply #7 on: May 05, 2011, 02:11:22 PM »
  These were on my bike when I got it a little over a year ago.  I've had them off to remove rear tire.  They are solid, the chrome is good and I like them.
Don
2qmedic
Simply Awesome!!!
« Reply #8 on: May 05, 2011, 07:34:40 PM »
Thanks for the info.
They do look nice, and nice looking fast black (like mine).  cooldude
Do you know if these are OEM or the MC Enterprises rails?
The OEM wrap around the front and are securely bolted in front of the saddlebage.
The MC Enterprises , I believe, wrap around the front alittle bit and are not bolted in front.
« Last Edit: May 05, 2011, 07:39:11 PM by 2qmedic » Logged
donaldcc
Palm Desert, CA
« Reply #9 on: May 05, 2011, 07:55:15 PM »
Don't think they are OEM because they have the little piece of triangular chrome at the back rear corners where the lights are attached in your first link.  the pic of the OEMs don't seem to have that.  didn't know what brand until now.
Don
« Reply #10 on: May 06, 2011, 08:13:12 AM »
There is more than that!
The way they fasten in the back is different and the OEM don't go up behind the license plate nor do the dual rails either.
Disco
Republic of Texas
« Reply #11 on: May 06, 2011, 08:23:09 AM »
The ones pictured are MC Enterprises.  The easiest way for me to tell the difference is that the OEM rails hug the contours of the bags and the MCE rails are straight down the sides and across the back.  After that, the OEM rails form a slight "V" under the rear fender.
One thing I prefer about the MCE rails over OEM is the antenna mount perches in the rear corners.   cooldude
22 CRF450RL, 19 BMW R1250RT
78 CB550K
71 Suzuki MT50 Trailhopper
2qmedic
Simply Awesome!!!
« Reply #12 on: May 06, 2011, 08:34:20 AM »
Those mounts on the MCE rails are one thing that I really like. Smiley
