September 16, 2025, 01:00:07 AM *
Author Topic: Why we don't "tweak" the night before...  (Read 868 times)
B
Capital Area - Michigan
« on: May 09, 2011, 08:12:17 AM »
When I adj'd valves I noticed the rubber valve cover bolt washers getting dry (12 yr old) so I ordered new ones ... They came in Thursday & I thought it would be nice to have them installed for my WkEnd trip since one was OCASSIONALLY misting. SNAP! and no bolts to be found...
So... about 250 miles down the road, my 16mm makeshift bolt is MORE THAN MISTING. I wish I had a picture of me sitting in front of Indianapolis NAPA waiting for the permatex to harden while I clean oil off the bike and chaps.
Why do I do that?
PS. No more leaks, great 1k WkEnd & bolt is due in tomorrow.
IT' s ALL about the journey.  cooldude
Ride Safe
Hope to meet a lot of you at Shanty Crk
B
« Reply #1 on: May 09, 2011, 08:46:03 AM »
as infrequently as one removes these valve covers its easy to forget that these bolts dont get torqued.  they have a hard stop just before  a good rubber gasket hits bottom so the last bit of tightening squeezes the rubber and then it hard stops....just a tiny bimp past that hard stop is all you need
B
« Reply #2 on: May 09, 2011, 05:38:33 PM »
You can feel it if you take the time.... & THEY ARE NOT CHEAP BOLTS.
DFragn
« Reply #3 on: May 09, 2011, 06:59:31 PM »
Curious
Was it an upper or lower fastener that was "misting"?
B
« Reply #4 on: May 10, 2011, 07:24:05 AM »
Lower but I replaced all 12; $2.50 each!
Rem ... I adjusted valves; don't know where it was before, but they were all showing their age.
« Last Edit: May 10, 2011, 07:28:41 AM by B » Logged
