February 02, 2026, 10:01:10 AM *
Author Topic: Hex Type Set Screws  (Read 1531 times)
G-Man
White Plains, NY
« on: May 09, 2011, 10:58:50 AM »
The caps of my handlebar risers are held in place with two set screws each.  They are supposed to turn with the use of a hex wrench.  I have both metric and standard hex wrenchs.  In both cases, one hex wrench barely grabs, then just spins while the next size up doesn't fit at all.  I picked up a kit that will spin them out, but I realized that I don't have enough clearance Clarence to use it.  Supposed to use it with a drill, but the outer two set screws will have the up-turned part of the bars in the way, and the inner two set screws are only about 2 or 3 inches apart (facing each other).
Any ideas how to back these suckers out?
Bobbo
Saint Charles, MO
« Reply #1 on: May 09, 2011, 11:54:33 AM »
You might need a hex key set that includes 64ths.  I've had a few tricky ones that were 7/64.  No metric one would fit, as a 2.5 mm would spin, and a 3.0 mm wouldn't fit.  Same with 3/32 and 1/8 wrenches.
G-Man
White Plains, NY
« Reply #2 on: May 09, 2011, 01:25:09 PM »
Exactly!!!!!
Was in Sears and didn't see any with smaller incremints than 32nds.  Guess I'll have to go through the internet or catalogue.  Nothing is easy, hunh?
Thanks, Bobbo!
Bobbo
Saint Charles, MO
« Reply #3 on: May 09, 2011, 02:03:50 PM »
I recommend the Wiha ball end set, number 36991.  Amazon has a good price:
http://www.amazon.com/Wiha-36991-13-Piece-Hex-Inch-ProStar/dp/B000LSJGQU
