February 02, 2026, 10:00:51 AM *
Author Topic: oil dipstick with temp gauge  (Read 5684 times)
YoungPUP
Valparaiso, In
« on: May 10, 2011, 06:47:47 PM »
Saw an oil dipstick with a temp gauge on it in a pic of someones bike here. who makes it, and where do i get one?  Thanks in advance. cooldude
99 STD (Under construction)
wizard -vrccds#125
Hitchcock Tx.
« Reply #1 on: May 10, 2011, 06:53:00 PM »
Just got 3 from Big Mike @ Valkyrie bling and more ! cooldude cooldude cooldude
« Reply #2 on: May 11, 2011, 07:40:11 AM »
Things like those temperature dip sticks are simply more thing to make you worry about what's going on with the motor and the paranoia never stops.
Get a chrome one and be happy!
« Reply #3 on: May 11, 2011, 08:01:48 AM »
this is the original and best.
http://www.teltru.com/s-94-motorcycle-and-atv-accessories.aspx
iliveforcurves
Proud owner of a 2003 Valkyrie Standard
Buchanan Dam, TX
« Reply #4 on: May 11, 2011, 08:04:48 AM »
The first thing I got for my Valk was one of those thermometer dip sticks.  I wasn't comfortable with a liquid cooled bike with no temperature guage.
Live to ride, ride to...uh, what was the question again?
2007 Kawasaki Ninja 500
2007 Kawasaki Ninja 250
1978 Yamaha SR500 (not running)
shortleg
maryland
« Reply #5 on: May 11, 2011, 11:50:04 AM »
  Think you will find that most Valks run from
190 to 200 Deg.
   Ran for Miles at 75 in 105 Deg and temp was about 195.
             Shortleg[Dave]
Mr Steve
Feeding Hills, MA
« Reply #6 on: May 11, 2011, 01:37:01 PM »
I got one off e-bay, I like it for the temp reading, but it sucks for oil checks.  I end up removing it and using my old chrome one when checking the oil, I can't get a good read with temperature one and fresh oil.
ricoman
Sarasota, FL
« Reply #7 on: May 11, 2011, 01:46:07 PM »
A worthwhile addition.
On the two Valks I've had with oil temp guages, both ran consistently 205-210.
Only from Oct. thru May did they usually run lower.
More important than the temp shown is seeing what is a consistent "normal" temp for your bike and then watching for an increase above that "normal". These guages are not precision instruments. Some will say they check with boiling water, OK fine, still an imprecise calibration.
Seeing the oil level can be a problem on the stainless guage shaft. I checked the level with a stock dipstick and then filed some cross hatches on the temp/dip stick to make a mark at the full level.
« Reply #8 on: May 11, 2011, 01:46:51 PM »
http://www.hondadirectlineofshadyside.com/stores/byBrand.asp?brd=Tel-Tru+Gauges&str=2&ID=372334188
I have the big dial on one bike and the smaller dial on the other.  I cannot read the little one very well while riding.
I cut a sliver-arrow of electrical tape and put it at 220*, the point when you want to pay attention. It is a good benchmark, and easy to see when looking down at 70MPH.  (though I only usually look in hot stop and go traffic)
donaldcc
Palm Desert, CA
« Reply #9 on: May 11, 2011, 09:06:33 PM »
How often has anyone with one of these ever made some immediate change, stop etc. because they saw a "sudden" increase in temp not discernible by temp light coming on or fan coming on and not going off??   Roll Eyes
« Last Edit: May 11, 2011, 09:10:31 PM by donaldcc » Logged
Don
« Reply #10 on: May 12, 2011, 05:17:07 AM »
when riding down to 25F in winter, I want to know that the oil is getting to at least 200F using 95% radiator block gets the temp there, if not water and oil stay about 150F wear increases greatly below 180F. oil temp shoulds always be in the 200-220F range, this burns off water, some acids and some experts state that some of an oils protective additves only work in that temp range.
www.bobistheoilguy.com
  http://www.noria.com/   http://www.lngpublishing.com/LNGmagazine/index.cfm  u can get their publications for free usually
Bullgoose
Bastrop, Tx
« Reply #11 on: May 12, 2011, 01:54:13 PM »
Check out this site: http://www.madcorider.com/products.html
Bill's a Valkyrie rider and makes all his products. No affil...
If it's worth doing, it's worth over-doing!
