February 02, 2026, 11:39:47 AM *
Author Topic: :99 Valk Trike build  (Read 1794 times)
namsgt1946
« on: May 11, 2011, 09:30:56 AM »
I am turning my Valk into a three wheeler.  Question regarding raked triple trees from someone riding them----I see most kits offer a 4 1/2 degree rake and I have been told that is not enough on a Valk.  I should use 6 or 8 degree.  What have you found and where do you purchase them?  Thanks
old grouch
Colorado Springs, CO
« Reply #1 on: May 11, 2011, 10:10:11 AM »
I triked my '99 I/S and have almost 30K on it.  I have an 8* tree from Daryl at VTXtreme.   http://www.xf6-custom.com/valkpartspage.html  He is a sponsor here and very good to work with regarding customer service and install.  I am very happy with it.  Steering effort is very low, not the least bit "twichy" on the straight roads and runs the twisties pretty much as fast as I want to go.  You should also go here:  http://www.triketalk.com/forum/honda-trikes/  and read about the subject.  Lots of opinions about the subject.  Stan
09/11/01 NEVER FORGET!
shortleg
maryland
« Reply #2 on: May 11, 2011, 11:41:01 AM »
   I helped on a build useing Cal sidecar kit.
 Goody and I found that you will need good
sholders and arms without 6 Deg of rake .
   So I think all here will tell you go with 6
Deg for your convertion.
         Shortleg[Dave]
ptgb
Youngstown, OH
« Reply #3 on: May 11, 2011, 12:42:30 PM »
Yep that.
We just did a conversion of an 03 Standard to a California Sidecar Trike for my wife. Mulled the 6° vs 8°; never even considered not raking or anything less than 6°. After talking to Daryl and then Old Grouch we went with an 8°. She is very happy with it in all aspects, from the twisties to high-speed straights (highway). It offers great handling and stability.
And... I would NEVER consider anyone else but Daryl at F6customs for a triple tree... he is quality people with a quality product!
« Last Edit: May 12, 2011, 05:37:30 AM by ptgb » Logged
Bad On 3
RIDIN THE BEAST ! !
CHICAGO IL. 60638
« Reply #4 on: May 11, 2011, 09:26:18 PM »
Hi i have a 99 interstate trike --mine is raked 8 degrees --i love it -it rides smooth -weather your in the twistes or on the straight road it is great -- i was told the valk need more than a 6 degree rake because of the size of the front end --i think a 6 would work great but i would go with a 8 on a valk. plus i love the way it looks ! ! !  in photo you can see the rake !! Everywhere i go people come to look at the trike --most  think its a car motor on it but even harley riders look and say nice bike -- GOOD LUCK !!
« Last Edit: May 11, 2011, 09:34:53 PM by Bad On 3 » Logged
Ridin Down The Road Of Life With My Friends !! What a Ride !!
TJ
Lake Placid , Fl.
« Reply #5 on: May 12, 2011, 06:29:54 AM »
 http://www.xf6-custom.com/valkpartspage.html     cooldude
« Reply #6 on: May 12, 2011, 02:25:05 PM »
Increasing the rake of the forks will result in a lower front end and the motor closer to the road.
ptgb
Youngstown, OH
« Reply #7 on: May 12, 2011, 02:35:27 PM »
Yep...
You will need fork extensions... I used 2 inch. Daryl will give you the right advice, no worries
