February 02, 2026, 10:00:56 AM *
Author Topic: Relocate Shifter  (Read 1738 times)
valkrdr99is
Grafton, OH
« on: May 11, 2011, 01:03:32 PM »
I just installed a 6 into 6 exhaust on my '99 Interstate. The shifter hits the middle pipe when I try and downshift. Does anyone know of a relocation kit, or has someone ran into this problem before? I thank you for any help.  John
Most motorcycle problems are caused by the nut that connects the handlebars to the saddle.  ~Author Unknown
roboto65
Conroe,TX
« Reply #1 on: May 11, 2011, 01:15:49 PM »
Have never installed those pipes but did you have to remove the lever to get them on if so maybe you slipped it back on one or two splines off.  If not then the PO had moved it down or reinstalled it that way and it was just off from the get go.
Allen Rugg
VRCC #30806
1978 Kawasaki KZ 650 project
« Reply #2 on: May 11, 2011, 01:25:12 PM »
I have Cobra pipes and I have to instal the shifter arm one or two teeth off one way or the other, but it will work fine, just tinker with it
Steve K (IA)
Cedar Rapids, Iowa
« Reply #3 on: May 11, 2011, 02:39:18 PM »
Get under there and look.  There are 2 places where you can make an adjustment.  Wink
States I Have Ridden In
valkrdr99is
Grafton, OH
« Reply #4 on: May 12, 2011, 09:15:38 AM »
Problem solved. I didn't see the second adjustment. Thanks for your help.
