March 23, 2026, 06:37:50 PM *
Author Topic: 1999 VALK. INTERSTATE CB INSTALLATION UNDER THE SEAT SKETCH  (Read 1474 times)
Lucky Luke
« on: May 12, 2011, 04:31:20 AM »
I HAVE BOUGHT A CB FOR MY VALK. INTERSTATE 1999 AND I KNOW THAT IT HAS TO BE INSTALL UNDER THE SEAT BUT I DO NOT KNOW HOW AS THERE IS THE RADIO UNIT THERE.
I NEED MORE DETAIL OR A SKETCH OF THE INSTALLATION IN ORDER TO AVOID MODIFYING THE WIRES.
IN DEED I AM NOT A MICHANIC AT ALL.
fordmano
San Jose, CA.
« Reply #1 on: May 12, 2011, 04:56:37 AM »
Not completly sure but I think it actually goes under the trunk has it's own rack that attaches to the underside of the rack the trunk sits on. If I am wrong I am sure someone will chime in and correct me.
I don't own one so I don't have real experience with the CB.
Good luck with your install.
83GS550
93XR650L TARD!
97WR250
99ValkyrieI/S Tri-tone
01YZ125(x2)
05DRZ-125
Cliff
Manchester, NH
« Reply #2 on: May 12, 2011, 05:35:50 AM »
My CB is loosely sitting on top of the battery (removed the rubber strap holding battery) .  The AM/FM radio is vertical behind the battery.
VRCC # 29680
« Reply #3 on: May 12, 2011, 05:42:34 AM »
The oem cb goes in a rack under the trunk bracket, the bracket should be available from Honda if not there on non cb models. Is it an oem cb? if so it should fit. Hoser
« Last Edit: May 12, 2011, 05:44:38 AM by Hoser » Logged
fordmano
San Jose, CA.
« Reply #4 on: May 12, 2011, 05:56:32 AM »
Here is an E-Bay link to a complete setup including the under trunk mounting rack. Sale is over but thought you would like to see all the parts laid out for informational and idea purposes.
http://cgi.ebay.com/ebaymotors/Honda-Valkyrie-Interstate-Factory-CB-Radio-Complete-/250803714723#ht_1436wt_948
83GS550
93XR650L TARD!
97WR250
01YZ125(x2)
05DRZ-125
« Reply #5 on: May 12, 2011, 06:00:10 AM »
The CB can easily fit behind the battery leaving the AM/FM in its spot.  It may be helpful to cut away some of the plastic in that spot.
fordmano
San Jose, CA.
« Reply #6 on: May 12, 2011, 06:01:24 AM »
Here is another complete setup and it is still available. $550.00 starting bid, Yowsa..
http://cgi.ebay.com/ebaymotors/Honda-Valkyrie-Interstate-HONDA-CB-RADIO-/270745736318?pt=Motorcycles_Parts_Accessories&hash=item3f09b4147e#ht_1660wt_948
83GS550
93XR650L TARD!
97WR250
01YZ125(x2)
05DRZ-125
Cliff
Manchester, NH
« Reply #7 on: May 12, 2011, 06:47:37 AM »
Thanks for the suggestion, It was installed by someone else, and I haven't really messed with changing it,,,, it seems to be fine where it is,,, I may have misused the term "loosely", as it isn't moving anywhere from where it sits once the seat is installed.
VRCC # 29680
F6BANGER
Albuquerque NM
« Reply #8 on: May 12, 2011, 07:26:48 AM »
Lucky Luke,
I have a cb mount you can have. Just pay shipping.
You would have to get your own mounting bolts.....Im sure they are cheap.
Bad On 3
RIDIN THE BEAST ! !
CHICAGO IL. 60638
« Reply #9 on: May 12, 2011, 02:49:38 PM »
Hi i installed mine behind the battery and put in a small piece of rubber on the side so its snug --wont move around --
Ridin Down The Road Of Life With My Friends !! What a Ride !!
Lucky Luke
« Reply #10 on: May 15, 2011, 02:15:25 PM »
thanks to all of you,
i will try to installl il behind the battery in first.
regards.
