February 02, 2026, 10:19:14 AM *
Author Topic: Gas cap seal  (Read 3412 times)
Chiefy
Sarasota, Florida
« on: May 12, 2011, 09:51:49 AM »
I need to replace the gasket/seal that goes under the gas cap.  I know you can't buy the part from Honda.  What material do you use to make your own?  Or is there an aftermarket one to be had?
Toledo Mark
Formerly Zeus661
Rossford, Ohio
« Reply #1 on: May 12, 2011, 01:08:08 PM »
I bought gasket material and made a ring that fit under the present rubber gasket.  What it did was make the thing thicker. Make sense?
Dropbox is a neat app I found that I use to store files and pictures of my Valk.
Chiefy
Sarasota, Florida
« Reply #2 on: May 12, 2011, 01:16:42 PM »
I'm an engineer   uglystupid2  that's no where near complicated enough.
tank_post142
south florida
« Reply #3 on: May 12, 2011, 02:39:05 PM »
HERE LET ME HELP:
1: apply viscous, non-hardening adhesive to the obverse of the seal augmentation apparatus at the 11:00, 13:00, 16:00 and 19:00 positions.
1.2: Mount device in required location
1.2.1: apply even pressure by engaging the articulated  storage security apparatus.  uglystupid2
« Last Edit: May 12, 2011, 02:41:01 PM by tank_post142 » Logged
I got a rock Sad
VRCCDS0246
Chiefy
Sarasota, Florida
« Reply #4 on: May 12, 2011, 02:59:16 PM »
HERE LET ME HELP:
Why didn't someone say that in the first place?
GOOSE
D.S. #: 1643
Southwest Virginia
« Reply #5 on: May 12, 2011, 06:07:17 PM »
CHIEFY....you might want to try this, it worked for me several times, take some vasoline on you finger and rub it on, and all over the original gasket.  for me it seemed to renew the old gasket, and it went back to it's original condition.  just a thought...it did work for me.
Red Diamond
Beaumont, Texas
« Reply #6 on: May 12, 2011, 07:38:13 PM »
I had the gas smell from my I/S and used vasoline on the gasket, it seem to help with the fume smells, but left a white powdery residual on the gasket surface. I wiped it off, since then I still smell gaseous fumes occasionally.
tank_post142
south florida
« Reply #7 on: May 12, 2011, 09:40:46 PM »
just about any petroleum based  gunk will swell the seal. BUT it will degrade the seal over time.
I got a rock Sad
VRCCDS0246
