February 02, 2026, 01:19:03 PM *
Author Topic: 1999 Valkyrie Clutch Handle w/master cylinder  (Read 2811 times)
99valkerieinterstate
Roseville,MN
« on: May 17, 2011, 07:35:00 PM »
Hey guys, I recently was left a bunch of motorcycles from my grandfather who passed away, one of them being a 99 Valkyrie Interstate. It is complete, minus the clutch lever and master cylinder. I've been having troubles finding a replacement, and am wondering if a clutch lever with master cylinder will work off of a honda goldwing around the same year, since they are easier to find? Thanks for the help.
« Reply #1 on: May 17, 2011, 08:06:46 PM »
Check pinwall on e bay. These folks always have a lot of valkyrie stuff. Hope this helps. Look at their ad-think it has a phone #. RIDE SAFE.
« Reply #2 on: May 17, 2011, 10:37:58 PM »
There's also Directline for new OEM parts.
http://www.hdlparts.com/fiche_select2.asp?category=Motorcycles&make=Honda&year=1997&fveh=3465
X Ring
VRCC #27389, VRCCDS #204
« Reply #3 on: May 17, 2011, 11:28:22 PM »
I checked Pinwall's ebay listings and there isn't a clutch master cylinder listed.
Marty
Mr.BubblesVRCCDS0008
« Reply #4 on: May 18, 2011, 03:24:15 AM »
Call Pinwall as sometimes they have stuff that has not been lists yet. Welcome to the world of the valks.  VTX 1800  master cylinders look close maybe even the 1300 might fit.
aslondon
VRCC #4321
Monticello, Fl
« Reply #5 on: May 18, 2011, 06:30:47 AM »
In answer to the question.  A GL1500 wing unit should NOT fit.  They are different. It is very possible that an early pre-gl1500 unit might fit. Part of the difference is the handlebar diameter 7/8 on the wing vs 1" on the Valk.
Al
Vrcc 4321
OverdueBill
Elkmont, Alabama
« Reply #6 on: May 18, 2011, 09:37:42 AM »
I would think that a VTX 1800 would work.  The part numbers are different on HDL but they seem to have the same stuff.  Both are 1" bars.  The VTX1300 won't work since it is a cable operated clutch.
« Reply #7 on: May 18, 2011, 11:21:53 AM »
It cost 251 bux new,319.62 with all the small parts needed. Shocked   Hoser
http://www.hdlparts.com/fiche_section_detail.asp?section=148029&category=MOTORCYCLES&make=HONDA&year=1997&fveh=3465
« Last Edit: May 18, 2011, 11:31:29 AM by Hoser » Logged
Roseville,MN
« Reply #8 on: May 18, 2011, 12:19:46 PM »
Thanks guys for all the helpful information. Funny thing is that, with the motorcycles I was left by my grandfather, when he passed away, one of them is 2002 Honda VTX 1800R. I was sure how interchangeable the parts were. I was looking at the 1996 Goldwing SE I also has left to me, which I thought would be a closer bike for "alike" parts, but ill have to check it out. Thanks.
Roseville,MN
« Reply #9 on: May 18, 2011, 12:25:28 PM »
I found a clutch master cylinder assembly from Pinwall, that is off of a 2002 VTX1800. I'm thinking that I'll pick that one up, since I'm not going to pull parts from one of the other bikes, since I want to keep them all in working order. Thanks again.
« Reply #10 on: May 18, 2011, 01:18:52 PM »
One of the other operator here has a 2002 VTX 1800  that is parked right next to my valk. If there is any difference in the master cylinders I can't tell it with the naked eye. Sorry about the bad advice on the 1300 clutch, I forgot that they are cable operated.
Roseville,MN
« Reply #11 on: May 18, 2011, 03:52:18 PM »
@Mr. Bubbles, I appreciate all the information that you guys have shared with me. Not a big deal about 1300vtx info, I have a 1800 so I might try that one out, otherwise Ill just pick one up online. thanks
shank
Morristown TN.
« Reply #12 on: May 18, 2011, 04:22:31 PM »
you could just sale me the valk . lol
