February 02, 2026, 11:39:40 AM *
Author Topic: Clutch Fluid Leak???  (Read 1418 times)
Tony Caro
« on: May 19, 2011, 01:24:23 PM »
Hello all.  I just bought a 99 Valkyrie about 3 months ago and I am concerned at the Cluth Fluid.  I verified the level and was below the Low Level Mark (way below).  I filled the reservoir and the bled the line.  After the bleeding I proceeded to re-fill again to the max level.
My problem? I cannot find any signs of leaks. I have verified all over and not even a drop in the floor on in the engine or slave unit.... so what is going on? Any ideas?  Shocked Shocked Shocked Shocked
Thanks in advance!
Grumpy
Tampa, Fl
« Reply #1 on: May 19, 2011, 03:15:59 PM »
If the piston on the slave cyl is leaking, you will not see it as it will go inside the motor. I would run it a while and see if the level drops again, it will normally go down a little as the clutch wears, but not a lot.
Tony Caro
« Reply #2 on: May 20, 2011, 04:55:28 AM »
 cooldude cooldude cooldude cooldude Thank you very much.  I will then proceed to buy a slave cylinder rebuilt kit!
« Reply #3 on: May 20, 2011, 08:59:36 AM »
If the slave cylinder is leaking, you can check it by tying the lever to the handlebars overnight.
Untie the lever and you will find very little to no pressure on the lever if the leakdown occurred. Of course if you let the lever return to the rest position it will reload and you will then have lost the indicator.
