February 02, 2026, 11:39:37 AM *
Author Topic: Fuel petcock better price  (Read 1905 times)
Warlock
Magnolia, Ms
« on: May 20, 2011, 05:00:22 AM »
A lot of people has spent to too much on the pingel fuel vales. Here's a place that sell the harley valves cheap. I ordered 48-9716 and they also sell the replacement gaskets. If you plan on installing a manual valve might be a cheaper. I will be putting one on my Valk next week. Will do a follow up on how it works and any problems installing. Here's the link.
http://www.powersportrider.com/CGI-BIN/ZCATJPG?catpub=BC0111C&catpage=468.00
David
« Last Edit: May 20, 2011, 10:37:10 AM by Warlock » Logged
X Ring
VRCC #27389, VRCCDS #204
« Reply #1 on: May 20, 2011, 06:35:04 AM »
http://www.powersportrider.com/cgi-bin/zcatjpg
David
David, your link brought up a blank page on the site.  I did some searching and finally found it.  http://www.powersportrider.com/CGI-BIN/ZCATJPG?catpub=BC0111C&catpage=468%20.00  Let us know how it goes.  That lever might be a little difficult to reach under the tank.
Marty
Warlock
Magnolia, Ms
« Reply #2 on: May 20, 2011, 10:40:22 AM »
David
Marty
I went back and re-did it. My plans are trying to make a piece to adapt to out fuel control. Don't know if that will work or not. Will be Monday or Tuesday before I get the valve. Also they have a gasket replacement for the petcock real cheap.
David
simon
OLD HICKORY. TN.
« Reply #3 on: May 20, 2011, 03:14:33 PM »
Hello Warlock,
  I bought one of these petcocks to use on my custom I built a couple of years ago. Your right, they look like a Pingel but I can assure you they don't last like a Pingel. Last Fall I was Winterizing my bikes and I tried to run the carb dry by turning the petcock off and running the engine. The engine just kept running and would never die. I pulled the gas line off the petcock and gas was still slowly coming out even tho I had shut it off. I pulled the petcock, dismantled it and replaced the O-rings and it still leaked. I got a Pingel for the custom. Problem solved. Later, Simon
Warlock
Magnolia, Ms
« Reply #4 on: May 20, 2011, 06:55:00 PM »
Hello Warlock,
Thanks, one thing for sure if it fails a pingel will be next.
David
